Osmc > Raspberry Pi & tv dongle...
A
Archive-8
Guest
Installed osmc on my spare Pi, then I installed samba server and tvheadend server.
Plugged in a spare tv dongle and in less than 2 mins i was scanning in channels via my tv aerial.
Going to play a bit more with it tomorrow :oops:
Don’t know if it will replace my hdhomerun.
Don't wear it out ;)
To configure tvheadend once installed via the “my osmc” option is really simple.
Go to your ip address of the Pi eg 192.168.x.x:9981
Username: osmc
Password: osmc
I did not have to install any drivers using these dongles:-
96BED88E-8419-479B-90E1-C516A14D56E0.webp 45A5337B-B20E-4E16-BA74-6064AB34BEA9.webp 3003D25C-9ADA-41E4-9797-666E3ABDDDDC.webp
It really was plug n play :D
The my osmc screen.
The samba server & tvheadend are under the shopping cart icon.
Looks like this
Once all installed, reboot the Pi and go to the web interface.
tvheadend setup wizzard:
select your language, and hit save & next.
agree with the settings below and hit save and next.
in the network 2 box pick dvb-t type.
Like this one below
Then hit save & next.
Then pick your local Freeview mux. (mines Stockland Hill) then hit save & next.
If all went well it should be scanning in the channels now, see below.
Once scanning is complete, hit save & next.
on the next screen tick all the boxes to map all services, create provider tags and create network tags, then hit save & next, see below.
lastly hit finish.
you have just setup tvheadend on the Raspberry Pi and tv dongle :D
just click the program title you wish to view and a box should pop up like this
Hit the play program button and a popup should appear like this.
open the file with vlc to stream your channel.
