Paksat MM1R 38.2E
Using RHCP, I can see 3946.5 & 4194 (MM1R) but nothing lockable (RH only)
1.8m PF, 5150LO (reference locked)
can you please check and share updated status
From
From my location here 17K North of the City of Nottingham UK, both beacons 4194.0 V & 3946.5 H still present - both polarity's scanned on my 2.2mtr PF which is undersized for this satellite - nothing new found.
Paksat MM1 Updated Cband Footprint Added on Website
Now C Band Coverage All over Europe.
IRIB MUX Testing on Paksat MM1
3900 H 27500
4-5 db signal difference between this tp and Paksat 1R. (1.8m dish Pakistan)
3900 H 27500
This is not too strong with me in Central UK on my 2.2m PF and needs about an extra 2.5dB to lock - any C-bander's in the UK managing to get a lock ?.
It was showing signal on the Combo, but below lock for me too..
Ok, thanks C, i think that little footprint spur from the main footprint is just a little bit too weak for us in the UK at the moment
To be honest John, that was on my circular LNB arrangement, I need to try my linear LNB on it.
I do not have the Green Lad on 38E at the moment, it is strapped up for Ku-Band. As soon as I switch it over to C-Band I will have a look.
The new footprint map does not seem to indicate stronger signal levels in the UK compared to the older map. The foorprint has changed only slightly via the addition of a narrowish European corridoor that was not present previously if I recall correctly?
Thanks MB, as you say the levels given on the beam spur footprint look as if intended for 5mtr plus headend stations... ?
Is that 3900H still active (Flysat lists it as 3898R, circular?) Getting 0 here. Only lock here is 3717V, 3m, outside footprint.
What about ku-band? SF8008 supreme blindscan finds one TP 11104V 3214 here. But it's only 1.4db
Unfotunately, 3900 H is gone now (Updated on lyngsat).
There is no TP active on Paksat MM1 currently.
Hi Is there a signal today? Irib 3899?
Still nothing
Just my signal right now... lockable both on 4.9m:
4170 H 500 3/4 DVB-S2 8PSK
4172 H 500 3/4 DVB-S2 8PSK
PakSat is no longer a satellite out of reach for small antennas, given the results I’ve now achieved, which gives me hope that, little by little, better reception conditions will be achieved even for small antennas, such as mine.
These few muxes that I’ve managed to pick up and lock onto from this satellite encourage me to hope that, under different weather and physical conditions, I’ll achieve better results.
I also tried using the neumoDVB app on Ubuntu 24.04 with the 6909x card and achieved the same promising results.
Just in case it wasn't apparent by now, The old Paksat-1R (launched in 2011) was raised to graveyard orbit a few weeks ago.
PakSat-MM1 remains at 38.2°E for the time being.
3.880 H AJK TV is solo here now, Pakistan TV now only on 3.870 H.
