Receivers which work with the MR and those which don't
Seansean said:
Works fine with Echostar DSB 808 Vi, no problems upgrading from 1.03 to 1.04 with a Fun5
for me it works with Echostar DSB 808 2ci Via, and upgraded from 1.08 to 1.19.
channels sometimes do not open quickly, depending on the transponder. keys entered by RC easily.
Does anybody have info or experience if MR works with Triax DVB 75 SI?
I tried to google but found no any information regarding this.
Cheers, TT
gazz said:
works fine on my OLD series HUMAX F1VACI..
best friend,
i've also humax f1vaci, but i can,t see de ducht channel.
what can i do to make it working.
your advice is very gratefully.
thanks ...........
hei Gazz,...
I've also old Humax f1vaci, but i can't see the canal+ tps and others.
how can i do to make working.
It's very grate if you can advice me.
Here the Hyundai hss1000ir works fine with the matrix rev. Cam ( + mrv 225 )
Use original firmware 1.07 on the reciever.
hi did you find out about your Manhattan works with Matrix? I have a Manhattan DSR 2500 CIP and i want to know which CCAM goes with it. Thanks
I tested Echostar DSB-2200 2ci (soft V801) with MRV2.19 but it doesn't work... :-(
Should I use a hier soft version (900 or 1000) tomake it work?
Sorry for the late reply, and no the 2500 does not work with the modern CAMs - none of the Magic or Matrix cams work in this model.
Hi all.
My Quali-TV QS1080IRCI receiver (software release 2.94 from March 29th 2005) works fine with:
  • Magic Cam - Penta 120 (with official Irdeto cards)
  • Matrix Reloaded - MR1230
  • Matrix Revolutions - MRV225
Doesn't work with my Matrix Reborn MRTV116a. Before the activatation of the firmware (with 777 code), the cam works fine, with several official cards, but after activation, the receiver only works fine with FTA channels. When going to an encrypted channel, sometimes i get a "NO RIGHT TO WATCH THIS PROGRAM". But most of the time, the receiver auto-reboots until i disconnect the cam. When it does work, the cam doesn't open any channel onened with both Matrix Reload e Revolutions.
26.08.2005: UPDATE - Matrix Reborn MRTV116c does work with this receiver and opens many, many channels...
Best regards.
Rui Costa, Portugal
Wont Initalise in Dreambox 7000. Initalised in Tecnomate 8000 CI MC. Put back into Dreambox and works Perfect.
radiotech said:
coship cdvb5300B works well with nagravision.
I'm buying a coship cdvb5300A is there much difference and will it work with this?
Thanks,
maiden30403
Hello,
I have Echostar 3000IP,
I want to update software, to have CAS SYSTEM;
PLEASE HELP ME.
Hello,
Does anyone know if the Technisat line of receivers works with the MR? Also, which CAM is better MR or MRV?
Cheers.
