>COR< said:Hello Rolf,
Echostar AD 3000 IP working fine, programming with CAS fine too.
Cheers,
Cor.
i have had a (very unused) ci 5100 for six years,still boxed,i could never get it to work with any cam dispite software upgrades.recognised cam sometimes wouldnt decode anything through it.at the time £200 down the drain.cowboy said:Ive spent the past 10 days trying all the advice from any forum I could think of and I still can't stop my Humax CI 5100 from displaying 'Invalid CI Module'
A lot of the advice said initialise the cam in another receiver....well that would be fine if I had another receiver.....If I had another receiver I wouldn't need the Humax!!!
I have now decided to sell the Humax and buy a Technomate, hopefully life will be a bit easier with that receiver!!
So as far as RolfW's survey goes I would definately give the Humax CI 5100 a thumbs down.....I tried and failed!!!!
Cheers Guys
Cowboy
EHCOSTAR DSB.2110. works, Matrix-Reloadedrolfw said:Started this thread so that any member can add their experiences.
Tested by me.
BEC 6600ci Works well, also for reflashing
Digiquest 2000ci Works well, also for reflashing
Hyundai HSS800ci Works well, but havent tried with uninitialised MR.
What I've heard.
Humax 5400 Works with the MR, has problems with initialisation after flash upgrade, but can be made to work
Hyundai HSS1000ci Doesn't work well at all with the patched embedded CAM.
Comag (Lidl cheapie) Works, not sure about flashing.
Echostar Whole range appears to work
Samsung 9500 Works
Nokia 9800 Works with some sofware versions
I have the same setup and cas3 Matrix-Reloaded, but clears for 60Sec then scrambles again then 10Mins later it clears again do you have the same problem,can you help. D.J.mosafu said:works fine with the older echostar 2110 2ci via with software(700).
nomic said:i have a amstrad drx550 and a matrix rev cam does this work having probs getting it running got a cas 3 to help me along the way
