Receivers which work with the MR and those which don't
Well I have to say aye for the Xtreme too....only thing is the MR clears much slower than the embedded cam of the receiver
SAMSUNG-702E Working Fine. Menus and all...
Regards,
John
Echostar AD3000ip (updated with V1100)
Constant pixellation and some freezing. With The MR inserted together with a Conax CAM/**3 card there is break-up, take the MR out and everything's fine.
So not working too good on my receiver, but the same CAM in Humax 5300 and Technomate 5500 is fine - so it's the Echostar at fault
Pixellation and eventual freezing on a Manhattan APCI 2500 with MR 1.08 and a Blue T. Card with 1.06 OS. A change of cam to Conax solved the problem for 1W so I assume it is a box/cam problem. Will try an earlier version of MR when I get the time.
Nokia 9800S - Can anyone tell me which software version to use? I have tried MR 1.055 and MR 1.080 without success! The Cam is not recognized by the receiver
Dear Rolf,
Do you know which software versions works with Nokia 9800S? I have tried MR 1.055 and 1.080! I am stuck, so your advise is appreciated!
rolfw said:
Started this thread so that any member can add their experiences.
Tested by me.
BEC 6600ci Works well, also for reflashing
Digiquest 2000ci Works well, also for reflashing
Hyundai HSS800ci Works well, but havent tried with uninitialised MR.
What I've heard.
Humax 5400 Works with the MR, has problems with initialisation after flash upgrade, but can be made to work
Hyundai HSS1000ci Doesn't work well at all with the patched embedded CAM.
Comag (Lidl cheapie) Works, not sure about flashing.
Echostar Whole range appears to work
Samsung 9500 Worksss
Nokia 9800 Works with some sofware versions
works great with echo 3600via silver m8
Technomate TM-5500CIp - works with MR1.05 MR1.08 MR 1.081 but had to program CAM using a laptop because the serial cable dreamloader module were "erroring" badly trying to use STB (Dreamloader display lights went out constantly & "invalid card inserted message"). Got it nearly working once. Rolfw thinks possibly there is not enough power to the CAM from the Technomate for upgrading.
my xtreme 6400 mr. 1o70 jams all channels even free to air
tried different cam slots lower and intialized on FTA. then change channels and all goes black screen NO VIDEO error.
Any ideas appreciated.
