Receivers which work with the MR and those which don't
Hi Guys, digital novice returning after some years away from this scene (do I really have to throw away my old D2-MAC?)... anyway, I bought a Technomate TM-5500 primarily because I could keep my old disk and motor and it has worked fine from day 1 with MR 1.080 I just need to work out how to program my own keys next.
Cheers all
Meridian
tirosh said:
My brother's Technomate TM5500 working fine with MR1.03.
Update - last night he had a problem with his setup. The CAM is making the receiver turn itself off and on. In fact at one point it lost all it's positions and these had to be put in again. The CAM is also refusing to initialise. So there may well be problems with this combination.
Hello mate... I did see a post on another site about this...I also have a TM5500. The solution was to put the CAM into a PCMCIA slot in a laptop and boot it. Apparently resets everything to its initial state and you can then install it again into the receiver.
Meridian
"Technomate 5500CIP" needed MR1.081 with a Funcard inserted at all times. Bought a "Technomate 5500CI Super" and the CAM works without a card. Both STB's had the same, latest software revision - Weird. Also had problems connecting to RS232 port to try and reload the software on the CIP.
HI guys
Comag (Lidl special) 2 Ci initialises MR1.081 quickly but channels not decoded
the same MR CAM work perfectly in my Echostar 2110 Ci Viaccess
Any thoughts on this perplexing problem
Do i need to downgrade MR version or is there a patch or fix to Rectify
Need to know cos my mate needs to get porned up with Multivision etc
Any Helpful Comments Much Appreciated
All the best
definite thumbs down to humax ci 5100,invalid cam message after reprogg of cam,now im searching for another receiver,anyone know about the manhattan starlight mx
I have a matrix reloaded 1.071 and tit card 1.06. Works fine for Conax 1West. If I program it for S*Y Italia 13E no picture.
Took Cam and card to friends echostar d-2500 ip - works fine for S*Y Italia.
Anyone else with Echostar ad-3000ip with same problem with S*Y Italia?
MR 1.07 works with Humax 5400Z only when like in my case updated to MR 1.10 and afterwards must be initiated in some other receiver (e.g. Nokia). After that it works fine.
Potatoelf
Grundig Selio DTR5210 S CI itself is buggy (it generates IR commands by itself!) but as far as I can tell MR is working fine. Grundig firmware is "106" and I've tried at least 1.07, 1.081 and 1.10 of the MR.
>COR< said:
Hello Rolf,
Echostar AD 3000 IP working fine, programming with CAS fine too.
Cheers,
Cor.
Hi Cor
I also have an Echastar AD3000 but am a complete novice. Please can you give me some advice on which programmer and cards I need. And how to obtain keys and program them.
Peter (Nottingham UK)
facing some problems with MR 1.100 + Echostar 2220 CI (with internal emu) ie picture freezing some explanation? conflicting soft? what about S*ca keys and nagra boxkey? thanks
Dear rolfw .
Does the Matrix Reloaded cam wotk with the Nokia 9800s with the latest software version MA2.0
MA2.0 is the latest updated software over the air for the nokia9800s.
What channels will can be opened and which card type shall it need?
Cheers rolfw
Not sure Shahid, there seems to be a question mark on that one, don't know anyone who's running that combination.
I've created a modification thats done to the cam to Fix forever the Nokia problems among other receivers and issues!
Search for my postings
Hiya Guys
Technomate TM5500 CI Super with Matrix Rev V1.03 workin like a dream, no prob's at all. Sometimes re-iniatialises but seems to cause no hassle so i reckon we have a success. Technomate take a BOW
Have Fun.
Rowlf:
In your thread you say the comag (cheapielidl job) will work with the MR (assume you mean the Matrix Rev CAM) if this is true, in basic noobie terms how does it work..please reply
