Advice Needed Receivers with the lowest Symbol Rate?
You can also end up with this screenshot if you use the webpage at the same time (though naturally, that takes a bit longer).
The TBSuniversal analyser software v6 looked interesting so I managed to find and download the v9 zip package.
No .exes to run only bat files.
more digging and looks like python script ...so I asked google AI if it would install and run under win7.
this was the reply:-
Will it run on Windows 7?
No, TBS Universal v9 is highly unlikely to run properly on Windows 7.
While the underlying TBS hardware drivers historically offered legacy support for Windows 7, the modern TBS Universal software suite is a Python-based utility that relies heavily on up-to-date core engines, modern media pipeline integrations, and recent software frameworks. Windows 7 lacks the required system libraries to support modern execution environments. To utilize newer releases like version 8.5 or version 9, you will need a modern operating system like Windows 10 or Windows 11.
once again I feel like I'm being herded in a direction I dont want to go..
Perhaps there is an earlier version that I can use ?
but chances are it was built long after win7 was considered dead.
This program has been under development on Windows 10 using Python since June,
so there is no older version.
However, it also works reasonably well with EBSpro.
OK, I will send pictures of the feed tomorrow along with dimensions
I am assuming it will slot nicely down the gap between the two feed arms, is it 40mm for the Bullseye LNB or modified to something else such as C band (60mm) ?
Evan
Feed dimensions, I assume (without taking the clamp off this afternoon), the girth is around 23-25cms
looks like it will do the job nicely CH ...
If minor ajustments are needed I'm up for it..
Done feed swapping in the past on lnbs purchased from the US....wierd oval shaped feeds which matched for the elongated dishes they used..
possibly direct TV ?
I'll take a chance without any further dimension details...assuming the price is right buddy.
Just the postage cost, same address ?
Dont know which address you used last time CH ...if it began 115 then no that was my shop address ...now sold..however it is the same street address just replace 115 with 121 (home address.)
let me know how much to paypal and where to send it.
cheers buddy.
The 2nd Bullseye lnb I ordered arrived this morning ...and in anticipation of CHs feed I thought Id tackle the case removal issue.
Attached is a sequence of photos showing how I achieved this..
Tools used were a ratchet G clamp ...and 2 flat baded blunt knives..
I would hope the photos explain the process.,,,but basically squeezing the longer plasic shell (non port side ) will allow the insertion of the first knife ...then work toward the red cap with the 2nd knife.
No clips of which there are 6 total...were damaged in this ritual.
rgds
VS
cheers buddy.
Evan
Really sorry, will ship to your address once packed. I doubt it will be any more than last time.
Regards
Stephen
Evan
Regards
Stephen
Cheers Stephen...looking forward to the project but no way I'm cutting the feed off the bullseye until I know exactly what I'm up against.
Just let me know as soon as it is posted what I owe you and an email address to send it to.
I'll keep checking my PMs
Will post tomorrow first class mail, you might get it Saturday.
Thanx CH feed arrived with this mornings post....
First job will be seeing if it fits nicely on the alcoa....if the fekkin rain ever stops that is.
drop me a PM on payment deyails.
rgds
See if it works first, you might be sending it back.
I doubt I would want to return it...
Already removed the red cap from the bullseye...and removed the second stepped scalar from the bullseye with snipe nosed pliers.
dremel next to remove the ally burrs...but as you can see from the pix the c120 feed on your feed fits snuggly inside the bullseye mouth.
I may have to fit a small section of pipe to make up the missing waveguide ..but potentially the 4 holes in the c120 flange could be continued through the bullseye flange allowing them to be bolted together...trapping the small pipe section between.
hope that makes sense..
The first offset scalar ring the one under the red cap now removed ..with a hacksaw and surface smoothed with glasspaper.
I daresay this one didn't need to be removed..
Advantages...less bulk
better access to smooth that second rind removed with pliers..
better range of movement if clamped at the join on the dish mount.
Now for a tricky bit..
replacing the missing waveguide..
The tube needs to be ideally Aluminium int diam 17mm ext diameter 20mm - ish
Of course such ally tube is unobtainium...except it sort of isn't ..
enter the sacrificial mechanical solder pump.
easily replaced for about £2...so why not
Looking good, by the way what is the interior diameter of the Bullseye cavity ?
You may find cutting the scalar off entirely and filing to sleeve into the new feed improves the transfer (I recall there was a performance drop at 12GHz when cavity length was over 8cms), hitting the exact focal point is the main criteria though, seconded by illumination of the entire parabola.
17mm would push the centre frequency up to 17GHz, slightly outside the Ku band.
I would usually sleeve out feeds with a section of coke or cider cans, very easy (to cut your fingers)
