Satdump software & wxsat reception
Here's a good one using V2 this Morning
Met M2-4 19/5/24 1350utc
As received apart from trimming the noise off the top & bottom of the image
Just had a look at the scans.I spotted that one ,because the setting are the same for both Meteors I assumed the it was M2-3.Nice to know that I got one from M2-4.15.6 pm.The times that I state are the record folder times.
Edit The image is not cropped that is the limit of my scan range
This is an odd one not sure which meteor it is I recon that it is M 2-4. 14. 5pm scan
They released a new version of satdump, nothing in it helps with my spike problem.
If I tune to 137.1 MHz and turn the LNB gain all the way down I get a huge spike right on that frequency, if I tune to 137.9 MHz I get the same, sometimes it affects some satellites, other times it doesn't it does affect the Meteor satellites, so I'm kinda at a standstill on those satellites until I can figure out where these spikes are coming from.
Any of you using the Nooelec or RTL-SDR type dongles have this problem??
This is the DC Offset spike. You can normally select a tuning offset so the software is looking at the spectrum away from this area. Some software can null the spike but it is difficult on a low cost dongle.
I've tried offsetting the LO frequency but it doesn't help.
Is there another way that i'm missing??
Use a smaller sample rate in RECORDER-DEVICE should do it.
Makes no difference but when I change it and restart it keeps going back to 2.048 for some reason
This is a decent scan .15.21 pm pass almost sure that it is M2-4.It looks lioke we are under all that cloud.
I've been getting all black scans on both Meteors, has something changed??
Weird, I have the same settings as you and as before, and now get nothing but black images on the downloads from the Meteors.
I get great passes on the NOAA satellites.
I don't know if you have the same problems as me.Satdump scans all passes most are fringe no chance of an image.I get black scans too.I always seem to get a good pass in the afternoon. Most are product.cbor about 551 bytes.
The meteors need quite a bit more signal for a successful decode compared to NOAA. Any Meteor folder with a 551 bytes folder size when hovering the mouse over the folder gets deleted immediately - its an empty folder.
For the status of the Mets keep an eye on this page - its useful to flag up expected frequency & mode changes
Yah that's all I see in the live folder, I just delete those, some just have an empty folder.
Here is the last pass on NOAA-18 just a few minuets ago.
Having some very nice weather right now, 73.3 degrees F (22.3 degrees C) and not a cloud in the sky. (at my location)
What I have found out lately is when there is a NOAA satellite in the same pass timing ( 5 to 10 min ) the NOAA satellite will swamp the downlink from the Meteor satellite.
