Satdump software & wxsat reception
I got a scan today, but it had some dead spots, I don't quite know what's causing these, maybe I have a problem with the antenna, I will look into this later.
Here you can see what may come up North this week, it might be hurricane Polo, but it might take a track to the North East and hit Texas, I will keep an eye out on this one.
Have they changed anything on M2-3 or 4 as I'm not getting scans as they pass over lately, I hope nothing gone wrong on my antenna.
I gave the antenna a rinse, it helped a bit, I might need to take it down and look it over for any corrosion problems, maybe later, it's over 95 outside today.
It is a bit fuzzy, don't know what's going on with that.
OK guys something has happened, all I'm getting is the following stuff.
This first one is all I get on the passes.
This is what I have on the main screen, so what the heck is going on?????
I am no expert.It looks like you have a strong signal.Schedule and con fig says over two hours for the next pass. Maybe some thing has changed in Settings.
OK, here is the last download today, there has to be something going on the antenna is working I can go to a different program and get tons of signals on the 137 MHz antenna, but the one for the Meteors has zip, I think the the ruskys are stopping the downloads for the US, my best guess.
Here is what I got, good signal but no data, and it passed right over.
I did get a download the other day, but my addled brain forgot to post it.Meteor M2-4 MSA pass 10-8-26C.webp
I had a pass yesterday on M2-4 but again I forgot about it, I also had to crop out some junk, but it was a pass.
And I had a pass on M2-3 today, but it didn't load anything, I think my antenna needs to pulled down and checked for anything corroded up or something.
Here is a screen shot of the M2-3 pass, I had a signal but nothing.
I normally get nothing from night passes.I normally shut Satdump down after the afternoon passes.I left it on tonight.I got two good scans from m2-3 the first is the MCIR scan the second is the shortwave ir scan.Not cropped.
Meteor 2-3 20:20 utc EL not known.
msu_mr_rgb_mcir_corrected.webp msu_mr_3.9_um_shortwave_ir_(uncalibrated)_corrected_map.webp
Ohhh I got a pass today from M2-4, it's not too good but it's working download.
