Satlink WS6916
try this
After power on, press ok into the main menu then start to set below functions:
For OSD Language/Channel Name/Band Width/ Carrier/ Modulate/FEC/Guard Interval/Output Level/Signal Source functions setting: You can press◀▶to change or select them.
For Frequency setting: You can press◀▶ move cursor and press ▲▼ key to change numbers.
For Service Provider/ Program Name setting: just input the name is ok.
For Factory Setting: press OK to confirm.
Good advice, but he hasn't logged on since shortly after that 2018 Post!
ah I see sry for that should read the dates lol
hello i have satlink ws 6916 firmware software upgrades so I need your help.
which version? you only need a usb to plugin and upgrade via usb
