Advice Needed Setup TCL Freesat
H3ALY
Sky Dish Connected to TCL Android TV.
South East England
I've moved into a property where by the last occupant has had a Sky installation.
There are two cables which come into the room, I've tried both of these plugged into the TV and do an automatic scan which seems to bring me anything and everything beside UK TV. If I perform a manual scan using ASTRA 28.2E I just seem to pick up 7 versions of ITV, is someone able to give some guidance on performing a better manual scan.
The options I have available are -
Satellite : Astra 28.2E
Position: A or B
LNB Power: On (If I turn this off I love all signal)
LNB Frequency: 9750_10750, 9750_10700, 5150, 5750, 9750, 10600, 10750, 11250, 1130, 11475,Universal
DisEqC input: Disable (Can't change this whilst LNB power is On)
UniCable: On (Again if I disable this, I get no signal.) There are also additional settings for Unicable
Tone22KHz : Off
Tone Burst: Disable
Frequency: 10774444KHz
Symbol Rate: 22000KB/s
Polarization: Horizontal Or Vertical
Any help greatly apprecicated!
The LNB is probably a Sky Q wideband type, it will need to be changed for a universal one. The usual recommendation is a Sky mk4 Quad LNB which should be a straight swap.
That LNB will be fine. There are more FTA HD channels on satellite, the only plus for Freeview IMO is it has WildEarth TV. There's a theory that current HD channels on Freeview may disappear around 2027 (IIRC) in order to ween people off terrestrial television and usher them onto streaming. If your television isn't Freesat branded it will only have now&next programme information for satellite channels.
If the cut parts of your aerial cable haven't been exposed to water it should be okay to reuse them, I'd put connectors on the cut ends and use a joiner.
Position: A or B
Tone22KHz : Off
Tone Burst: Disable
Hi,
Did you have any luck with setting up Freesat on your TCL?i
I am in a similar situation, I have a 10 year old Dual LNB ( old Sky system) with the two cables which I have been using on a Zgemma box, unfortunately the box has started playing up so was hoping to connect directly to the sat input on the TV.I connected to the sat cable and scanned for channels on Astra 28.2E but it came up empty. However ,if I try entering different band frequency setting found online. ( e.g 10500) I can pick up some channels . I get around 8 channels on the frequency ( God channel etc.). I have contacted TCL U.K but they are unable to help. I have proved the LNB is suitable (Sky J4LS) I have tried both cables on another Freesat receiver and signal strength and quality are excellent. There is no signal on the TV until I mess around with the frequency so I can only assume that is where the problem is. Has anyone got any idea on the correct Freesat frequency or any other suggestions
Many thanks.
Post some photos of the settings you are using. As a start make sure LNB Frequency is set to Universal.
Hi,
Many thanks.
Take your pick from really any frequency in the first column
THere is a chance the LNB local oscillator has drifted slightly now it is a few years old.
