Some success with ITV HD on Fortec Passion
gnr said:
Thanks but the site will not let you register and all the forum posts are private so do not show up
Try posting as a guest in the 'Registration Problems' forum. This is open to non-members (obviously).
will try later then! but if you have no sound..................having both seems good!!
KyleRickards said:
Just downloaded 119, sorted! Now have ITV HD!! But no sound... Is there anything at the moment being broadcast?
London looks quite nice in HD.
GNR - I had that problem the other morning but it allowed me to register kind-of mid morning so it will let you in eventually.
Many thanks to everyone who have saved my sanity over ITV!
Kyle
Good stuff, try experimenting with different PIDS for Service ID and PMT PID (always keep your Video PID, Audio PID and PCR PID constant , just make multiple copies of the channel. For info I get perfect results with the following settings.
Service ID - 0
Video PID - 3401
PMT PID - 16
PCR PID - 3401
Audio PID - 3402
HD Box - Ticked
Success at last, both video and audio together :)
Thanks Ratchet, used your channel list (I'm magwitch at sataid). I just need to convert to DiseqC 1.0, hopefully ITV HD remains working!
Strange that those pids are ones I used before :confused:
Llew
Would there be any other place to get build 119, I have searched but nothing seems to be relevant
Llew
Nice one, it should last - I've had it working rock solid since Thursday night. I just assumed ITV had changed something at their end until I saw that most people still couldn't get it. I made multiple copies of the channel with various PID combos and miraculously one of them worked. :cool:
Setedit v.119 -
Hmmm, deleted channel and rescanned just using Passion and the settings you said Ratchet, put onto USB, enabled HD flag on PC, transferred back and still no sound... odd... is there something else I need to alter on the Passion?
Thanks Llew but does not seem to work either, no HD box to tick (should there be one)?
Hi Llew. Many thanks. But this seems to be V1.00 build 118 with no HD tick box? Or am I missing something? Paul
I added the channel from scratch using Setedit rather than edit an existing channel. Have you tried various PID combos, i.e. Service ID 10510 and / or PMT PID 3400 ? You may want to give my channel list a go, I've attached it here. ITV HD is channel 0024 but make a backup / copy of your own database in case this one doesn't work.
This is odd, I have ensured the Audio PID is set to 3402 on PC. On Passion it showed as 8192. So I tried another edit, again using 3402 and I now have 11594 listed as the PID. Am I doing something completely wrong?
Kyle
Kyle having the same probs as you..........on all counts!!!
Guys, I feel your pain - I went through the same thing a few days ago until it just clicked. Either try my channel list posted above or keep trying with Setedit using various combos.
Tried your channel post Ratchet and many thanks for the posting alas now i have the passion reporting no video or sound but i still have the sound?
'tis a strange world
Ratchet it works for me! Thank you! I uploaded your channel list via RS232 using Setedit V1.01 build 124 (the latest one). Bingo! ITV HD pictures and sound!
Ratchet, just as a check, i went to lux and BBC HD and only got sound there too
Right... am having to write things down now!
Have tried:
Serv 0 PMT 16 (Pic/No sound)
Serv 10510 PMT 16 (Sound/No pic)
Serv 0 PMT 3400 (Pic/No sound)
Serv 10510 PMT 3400 (Sound/No pic)
So am I missing something blindingly obvious like another combo?
Kyle
(PS - sorry all!!)
Sorry, mistaken file my PC. Will change when I find it :eek:
(Edit) Have now (hopefully) uploaded the correct file.
gnr which version of Setedit did you use to upload it to the STB? V1.01 build 124 (the current one from the Satedit web site) works for me when I use Ratchet's channel list bot via RS232 AND through a USB stick. Nice one Ratchet!
