Top Tip T2-MI reception on E2 STB with SDG image - A complete step by step guide
3 streams on 5E/12073H
as Enosat says, there are 3 Streams, 1 of which is coded
with PIDs 4095; 4706 coded; 4716
12072.72 H
T2MIpid-4095 , PLP 0
T2MIpid-4706 , PLP 0
T2MIpid-4716 , PLP 0
12245.34 V
T2MIpid-4096 , PLP 0
T2MIpid-4097 , PLP 0
12245V is probably planning to shut down
no change, everything is as it was (only the SID has changed)
12073 H
T2MI 4097 - SID 801
T2MI 4096 - SID 800
4096 12073H
T2MI 4095 - SID 110
4095 12073H
12245 V
T2MI 4097 - SID 801
4097 12245V
T2MI 4096 - SID 800
4096 12245V
12073 H
T2MI 4097 - SID 801
T2MI 4096 - SID 800
T2MI 4095 - SID 110
12245 V
T2MI 4097 - SID 801
T2MI 4096 - SID 800
When will it be new Ciefpsettings?Please create new,please help,thanks.
##### Astra 4A / SES-5 @ 4.8° E #####
:: T2Mi :: 12073 H 30000 2/3 MX-710 :: pid 4096 ::
- Перший
- Суспільне Культура
- Рада
- Армія ТБ
- 1+1
- ICTV
- Iнтер
- Ми-Україна
- Піксель
Just switch to 12245V and you can watch them
wrong lamedb or wrong astra.conf or wrong userbouquet or wrong astra script - have you checked them all?
if use namespace XXXX0000
-- KRRT 4.8
f12073h48b = make_t2mi_decap({ name = "SRV_321 12073H T2-MI PLP0", input = "http://127.0.0.1:8001/1:0:1:321:107B:55:300000:0:0:0:", plp = 0, pnr = 0, pid = 4097, })
make_channel({ name = "12073krrt1", input = { "t2mi://f12073h48b", }, output = { "http://0.0.0.0:9999/12073h48/4097plp0", }, })
f12073h48c = make_t2mi_decap({ name = "SRV_320 12073H T2-MI PLP0", input = "http://127.0.0.1:8001/1:0:1:320:107B:55:300000:0:0:0:", plp = 0, pnr = 0, pid = 4096, })
make_channel({ name = "12073krrt2", input = { "t2mi://f12073h48c", }, output = { "http://0.0.0.0:9999/12073h48/4096plp0", }, })
f12245v48a = make_t2mi_decap({ name = "MX", input = "http://localhost:8001/1:0:1:320:35:55:300000:0:0:0", plp = 0, pnr = 0, pid = 4096, })
make_channel({ name = "12245krrt1", input = { "t2mi://f12245v48a", }, output = { "http://0.0.0.0:9999/12245v48/4096plp0", }, })
f12245v48b = make_t2mi_decap({ name = "Service 801", input = "http://localhost:8001/1:0:1:321:35:55:300000:0:0:0", plp = 0, pnr = 0, pid = 4097, })
make_channel({ name = "12245krrt2", input = { "t2mi://f12245v48b", }, output = { "http://0.0.0.0:9999/12245v48/4097plp0", }, })
00300000:0035:0055
    s 12245340:30000000:1:2:48:2:0:1:2:3:2
00300000:107b:0055
    s 12072720:30000000:0:2:48:2:0:1:2:3:2
0320:00300000:0035:0055:1:0:0
T2MI 12245V MX
p:T2-MI,c:151000,C:2600,f:5
0320:00300000:107b:0055:1:0:0
T2MI 12073H 0320
0321:00300000:0035:0055:1:0:0
T2MI 12245V Service 801
p:T2-MI,c:151001,f:5
0321:00300000:107b:0055:1:0:0
T2MI 12073H 0321
if use namespace XXXX1234
-- KRRT 4.9
f12073h49b = make_t2mi_decap({ name = "SRV_321 12073H T2-MI PLP0", input = "http://127.0.0.1:8001/1:0:1:321:107B:55:312F28:0:0:0:", plp = 0, pnr = 0, pid = 4097, })
make_channel({ name = "12073krrt1", input = { "t2mi://f12073h49b", }, output = { "http://0.0.0.0:9999/12073h49/4097plp0", }, })
f12073h49c = make_t2mi_decap({ name = "SRV_320 12073H T2-MI PLP0", input = "http://127.0.0.1:8001/1:0:1:320:107B:55:312F28:0:0:0:", plp = 0, pnr = 0, pid = 4096, })
make_channel({ name = "12073krrt2", input = { "t2mi://f12073h49c", }, output = { "http://0.0.0.0:9999/12073h49/4096plp0", }, })
f12245v49a = make_t2mi_decap({ name = "MX", input = "http://localhost:8001/1:0:1:320:35:55:31AFD5:0:0:0", plp = 0, pnr = 0, pid = 4096, })
make_channel({ name = "12245krrt1", input = { "t2mi://f12245v49a", }, output = { "http://0.0.0.0:9999/12245v49/4096plp0", }, })
f12245v49b = make_t2mi_decap({ name = "Service 801", input = "http://localhost:8001/1:0:1:321:35:55:31AFD5:0:0:0", plp = 0, pnr = 0, pid = 4097, })
make_channel({ name = "12245krrt2", input = { "t2mi://f12245v49b", }, output = { "http://0.0.0.0:9999/12245v49/4097plp0", }, })
00312f28:107b:0055
    s 12072720:30000000:0:2:49:2:0:1:2:3:2
0031afd5:0035:0055
    s 12245340:30000000:1:2:49:2:0:1:2:3:2
0320:0031afd5:0035:0055:1:0:0
T2MI 12245V MX
0320:00312f28:107b:0055:1:0:0
T2MI 12073H 0320
0321:0031afd5:0035:0055:1:0:0
0321:00312f28:107b:0055:1:0:0
T2MI 12073H 0321
-- KRRT 4.8
00300000:0035:0055
00300000:107b:0055
T2MI 12245V MX
T2MI 12073H 0320
T2MI 12073H 0321
-- KRRT 4.9
00312f28:107b:0055
0031afd5:0035:0055
T2MI 12245V MX
T2MI 12073H 0320
T2MI 12073H 0321
Please this is lamedB file,this is error,please help,and links url astra-sm thanks.
Hello everybody. Can anyone help me with ZeonBud 12073? I can't do it. THANKS.
astra-sm running ?
