i can`t do the tutorial some thing wrong all i want an enigma backup i use amiko alien 8900 to match tv on express 53eYou're posting in the wrong section then.
Go back to the beginning and follow the instructions EXACTLY. We are a technical forum and dont give users the easy route out. If you cant get it going from the instructions supplied then you have to do without.
3. Getting the feed channel
Every Enigma2 receiver when it gets tuned to a T2-MI transponder will not download the channels directly (although this automation has to be implemented in the near future). Instead the tuner will lock and download a data channel. In the following example we used a T2-MI transponder on the C band of Express AM7 satellite on 40E.
In this image you can see that this frequency (3685L) is tuned normally with the internal tuner.
Now, scanning the frequency downloads the data service (it might take a while).
This one is Multistream (according to Lyngsat and Flysat). But I also noticed I have signal and lock without Transponder stream type to 'Multistream'.T2-MI is *not* multistream. You can have T2-MI encapsulated into multistream as well as not.
what is your box? i can give you files image?This one is Multistream (according to Lyngsat and Flysat). But I also noticed I have signal and lock without Transponder stream type to 'Multistream'.
I have installed astra-sm and tried adding the bouquet manually. Perhaps I did not do that right, can you give me some tips?
My box is VU+ Zero 4k, any Enigma2 settings will do.what is your box? i can give you files image?
