Top Tip T2-MI reception on E2 STB with SDG image - A complete step by step guide
Go through the instructions from the start line by line again. If that still doesnt work, do it AGAIN!
OpeNFR does not seem to have astra-sm on its feeds! Maybe try another image?
Yamal 402 12694 V 15284 is working with SDG on Gigablue HD Quad+ with astra-sm.
I just made a new config for 54.9E, working great!
Here's my new config in astra.conf
-- RTRS 54.9E
f12674rtrs0 = make_t2mi_decap({
        name = "12674V T2-MI  PLP0",
        input = "http://127.0.0.1:8001/1:0:1:320:3A2:0:225B182:0:0:0:", -- required
        plp = 0,
        pnr = 0,
        pid = 4096,
f12674rtrs1 = make_t2mi_decap({
        name = "12674V T2-MI  PLP1",
        plp = 1,
        pnr = 0,
        pid = 4096,
f12694rtrs0 = make_t2mi_decap({
        name = "12694V T2-MI  PLP0",
        input = "http://127.0.0.1:8001/1:0:1:320:3A2:0:225B196:0:0:0:", -- required
        plp = 0,
        pnr = 0,
        pid = 4096,
f12694rtrs1 = make_t2mi_decap({
        name = "12694V T2-MI  PLP1",
        plp = 1,
        pnr = 0,
        pid = 4096,
make_channel({
        name = "12674rtrs0 ", input = { "t2mi://f12674rtrs0", },
        output = { "http://0.0.0.0:9999/rtrs/12674plp0", },
make_channel({
        name = "12674rtrs1 ", input = { "t2mi://f12674rtrs1", },
        output = { "http://0.0.0.0:9999/rtrs/12674plp1", },
make_channel({
        name = "12694rtrs0 ", input = { "t2mi://f12694rtrs0", },
        output = { "http://0.0.0.0:9999/rtrs/12694plp0", },
make_channel({
        name = "12694rtrs1 ", input = { "t2mi://f12694rtrs1", },
        output = { "http://0.0.0.0:9999/rtrs/12694plp1", },
and the bouquet content
#NAME RTRS T2-MI (54.9E)
#SERVICE 1:64:16:0:0:0:0:0:0:0::---------- RTRS T2-MI (55E) ----------
#DESCRIPTION ---------- RTRN T2-MI (55E) ----------
#SERVICE 1:0:1:3F2:3182:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12674plp0:01 ПЕРВЫЙ КАНАЛ
#DESCRIPTION 01 ПЕРВЫЙ КАНАЛ
#SERVICE 1:0:1:3FC:3182:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12674plp1:02 РОССИЯ-1
#DESCRIPTION 02 РОССИЯ-1
#SERVICE 1:0:1:406:3182:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12674plp0:03 МАТЧ!
#DESCRIPTION 03 МАТЧ!
#SERVICE 1:0:1:410:3182:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12674plp0:04 НТВ
#DESCRIPTION 04 НТВ
#SERVICE 1:0:1:41A:3182:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12674plp0:05 ПЯТЫЙ КАНАЛ
#DESCRIPTION 05 ПЯТЫЙ КАНАЛ
#SERVICE 1:0:1:424:3182:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12674plp0:06 РОССИЯ-К
#DESCRIPTION 06 РОССИЯ-К
#SERVICE 1:0:1:42E:3182:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12674plp1:07 РОССИЯ-24
#DESCRIPTION 07 РОССИЯ-24
#SERVICE 1:0:1:438:3182:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12674plp0:08 КАРУСЕЛЬ
#DESCRIPTION 08 КАРУСЕЛЬ
#SERVICE 1:0:1:442:3182:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12674plp1:09 ОТР
#DESCRIPTION 09 ОТР
#SERVICE 1:0:1:44C:3182:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12674plp0:10 ТВ Центр
#DESCRIPTION 10 ТВ Центр
#SERVICE 1:0:1:7DA:3196:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12694plp0:11 РЕН ТВ
#DESCRIPTION 11 РЕН ТВ
#SERVICE 1:0:1:7E4:3196:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12694plp0:12 Спас
#DESCRIPTION 12 Спас
#SERVICE 1:0:1:7EE:3196:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12694plp0:13 СТС
#DESCRIPTION 13 СТС
#SERVICE 1:0:1:7F8:3196:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12694plp0:14 Домашний
#DESCRIPTION 14 Домашний
#SERVICE 1:0:1:802:3196:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12694plp0:15 ТВ3
#DESCRIPTION 15 ТВ3
#SERVICE 1:0:1:80C:3196:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12694plp0:16 Пятница
#DESCRIPTION 16 Пятница
#SERVICE 1:0:1:816:3196:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12694plp0:17 Звезда
#DESCRIPTION 17 Звезда
#SERVICE 1:0:1:820:3196:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12694plp0:18 МИР
#DESCRIPTION 18 МИР
#SERVICE 1:0:1:82A:3196:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12694plp0:19 ТНТ
#DESCRIPTION 19 ТНТ
#SERVICE 1:0:1:834:3196:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12694plp0:20 МУЗ ТВ
#DESCRIPTION 20 МУЗ ТВ
#SERVICE 1:0:2:456:3182:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12674plp0:ВЕСТИ ФМ
#DESCRIPTION ВЕСТИ ФМ
#SERVICE 1:0:2:460:3182:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12674plp0:МАЯК
#DESCRIPTION МАЯК
#SERVICE 1:0:2:46A:3182:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12674plp1:Радио России
#DESCRIPTION Радио России
Thank you for the astra.conf file, is it necessary to edit the lamedb file?
Yes, you also need to create the "fake" source channels, as described in the first post.
McelliotG what size dish are you using for 54.9E?
My 1.30 offset dish! The eastern part of my arc needs a little finetuning though....
I don't have a image on 12674V, on 12694V works all fine.. Can you give advice? Thank you.
yes i confirm, there is no signal on 12.674 V on 54.9E
Cardiff
yes, at 12694 I have 9.8 dB (NMR=1,7 db, but at 12674 I only have 8.2 dB(NMR=0,5db
MCelliotG
I need astra.conf and the bouquet content for frequencies 3655 L 15284 & 3705 L 15284 at 49E C-Band
Thanks for your help me
Regards
MCelliotG
Regards
I cannot provide that, I have no C band reception!
MCelliotG
Regards
Good I got for these to give little in my vu + zero 4k and are working well.
-- RTRS 49.0E
f3704rtrs0 = make_t2mi_decap({
        name = "3704H SID 0x320",
        input = "http://127.0.0.1:8001/1:0:1:320:3A2:0:1EB0E78:0:0:0:",
        plp = 0,
        pnr = 0,
        pid = 4096,
make_channel({
        name = "3704rtrs0", input = { "t2mi://f3704rtrs0", },
        output = { "http://0.0.0.0:9999/rtrs/3704plp0", },
#SERVICE 1:0:1:406:E78:0:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/3704plp0:Match!
#DESCRIPTION Match!
#SERVICE 1:0:1:410:E78:0:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/3704plp0:NTV (0h)
#DESCRIPTION NTV (0h)
#SERVICE 1:0:1:41A:E78:0:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/3704plp0:5 Kanal (0h)
#DESCRIPTION 5 Kanal (0h)
#SERVICE 1:0:1:438:E78:0:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/3704plp0:Karusel (0h)
#DESCRIPTION Karusel (0h)
#SERVICE 1:0:1:44C:E78:0:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/3704plp0:TV Centr (0h)
#DESCRIPTION TV Centr (0h)
#SERVICE 1:0:1:424:E78:0:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/3704plp0:Rossiya K (0h)
#DESCRIPTION Rossiya K (0h)
#SERVICE 1:0:1:456:E78:0:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/3704plp0:Vesti FM
#DESCRIPTION Vesti FM
#SERVICE 1:0:1:460:E78:0:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/3704plp0:Radio Mayak
#DESCRIPTION Radio Mayak
#SERVICE 1:0:1:3F2:E78:0:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/3704plp0:Perviy kanal (0h)
#DESCRIPTION Perviy kanal (0h)
I think both T2-MI on 55E have stopped! Does anyone receive them?
I can't test it because I can only get it up to 50E here in Azores.
Another from 49E
4018 L
f4018rtrs1 = make_t2mi_decap({
        name = "T2_MI_+1_Ulyanovsk",
        input = "http://127.0.0.1:8001/1:0:1:320:1:1:1EB0FB2:0:0:0:",
        plp = 1,
        pnr = 0,
        pid = 4096,
make_channel({
        name = "4018rtrs1", input = { "t2mi://f4018rtrs1", },
        output = { "http://0.0.0.0:9999/rtrs/4018plp1", },
#SERVICE 1:0:1:3FC:FB2:1:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/4018plp1:GTRK Ulyanovsk
#DESCRIPTION GTRK Ulyanovsk
#SERVICE 1:0:1:42E:FB2:1:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/4018plp1:Rossiya 24 Ulyanovsk
#DESCRIPTION Rossiya 24 Ulyanovsk
#SERVICE 1:0:1:442:FB2:1:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/4018plp1:OTR Reportyor 73 (Obshestvennoe TV Rossii)
#DESCRIPTION OTR Reportyor 73 (Obshestvennoe TV Rossii)
#SERVICE 1:0:1:46A:FB2:1:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/4018plp1:Radio Rossii (0h)
#DESCRIPTION Radio Rossii (0h)
