- TM 5402HD
Sky+ UK.
- Scottish Borders
Blimey not much left of interest on 15W these days! Just had a quick look after rigging an lnb for 14W.
Here are the muxes you find at 15.0W, including the two with symbol rates of 107140.I have 11014V on 15W dreamsat. Or it it on 14W? Hard to tell where I am.
Not much TV at 15.0W, only a few feeds on the upper band. Unfortunately, the MTN package is encrypted.and which transponder carries something....worth watching?
Is this MTN channel great?
I don't see those muxes satesco. I get 10979V and 11036V, and an adjacent one not locked at ~ 11136V.
I checked the two muxes (11013 V and 11137 V) at 15.0W; as you can see in the screenshot, both have the same symbol rate-107140. Look at the time and date on my Crazyscan.
I think the errors you have on the spectrum may be due to the card you are using, probably 6903. I think that's why the errors on your spectrum are occurring.
But..., it's not excluded that they're coming from another beam(T12V North Sea 56), which doesn't cover my area.
Because these transponders have this high symbol rate, they can only be locked with the 6903x/6909x card, which has the stid135 demod.
(Strangely, FlySat deleted my report on these two transponders, because other users failed to catch and lock them. It happens this often, such as false reception reports)
11375 V,8748,3/4,S2-MTN TV package(enco),According to Telstar 12 Vantage (15°W) - All transmissions - frequencies - KingOfSat there is BBC One on 12597 V and some other channels on 11377 V, can you guys confirm?
11377V is the new frequency for the MSNBC Power Vu mux - it moved frequencies a couple of weeks ago.
The "BBC1" apparently has a bit rate of 80b/s - thats not going to give much of an imageAt most a static card. I cant get any signal coming off that frequency currently though
12597 V,45000,5/6,8PSK-Service +Navy TV
