Help Required TNT Sat card update
Ok spoke too soon. Seems like the card has become disabled or something.
Lol, that's the kind of thing that would happen to me!
Sent from my thl 2015A using Tapatalk
Be aware the early series Fransat cards are being turned off by the end of the year & a replacement will be required.
I am aware , thanks .. anyway to update it please ?
OMG, I'm not the only one trying to do weird things.
So if I understand fine it is posible to activate the new card using oscam?
My situation is that In the past regular clines from internet could open the tntsat channels. unfortunatelly they don't any more.
so I'm thinking on buying a brand net tntsat card. and put it on a usbreader on a raspberry/pine64 (latest oscam server there) and use that as an internal server resharing to my decos using ccam.
Do you think it should work I really do not want to have two sat receivers.
I've read there is now another manual key to add to the reader we need to add the AESkeys and the DES key? would it be posible to get any advice on where to get and use those?
Thankyou I really apreciate any information that help me with the setup. actually my dad will je je I do not speak a word of french ;-)
I think most of the TNTSAT channels are available in the BIS package from Hotbird 13E
hello
just a long shot anyone here interested in helping me get my tntsat card to work with a card reader
and if anyone needs there card activating in a real tnt decoder box i have one
thanks
Dom
Hi
not sure if this is the right place to post this but here go's
i am running a windows 7 64 bit server with DVBlink server installed
a dvds/s2 card all this works fine with the FTA channels that are not encrypted
i have a TBS3102 5 Crystal Phoenix Card Reader and a TNTsat card,
the problem that i am haveing is that i can't get it to decrypted the encrypted channels
below is the log file if anyone could help it would be great
thanks
#START#
C:\Program Files (x86)\DVBLogic\DVBLink\sources\TVSource-2\plugins\ACamd.dll
13:20:52.717: ACamd v0.6.2.0
13:20:52.726: MD-API Version 01.06
13:20:52.729: systems: registering CA system Cardclient, pri -15, ident 1000
13:20:52.729: structloaders: registering loader cardclient config
13:20:52.729: cardclients: registering cardclient Newcamd
13:20:52.729: cardclients: registering cardclient Newcamd2
13:20:52.729: cardclients: registering cardclient CCcamN
13:20:52.729: cardclients: registering cardclient Radegast
13:20:52.729: cardclients: registering cardclient Camd35
13:20:52.729: structloaders: registering loader smartcard data
13:20:52.729: systems: registering CA system SC-Irdeto, pri -10, ident 1001
13:20:52.729: feature: using feature SMARTCARD
13:20:52.729: registering Irdeto smartcard (id 49726474)
13:20:52.729: systems: registering CA system SC-Seca, pri -10, ident 1002
13:20:52.729: registering Seca smartcard (id 53656361)
13:20:52.729: systems: registering CA system SC-Viaccess, pri -10, ident 1003
13:20:52.729: registering Viaccess smartcard (id 56696173)
13:20:52.729: systems: registering CA system SC-Conax, pri -10, ident 1004
13:20:52.729: registering Conax smartcard (id 436f6e78)
13:20:52.729: systems: registering CA system SC-Cryptoworks, pri -10, ident 1005
13:20:52.729: registering Cryptoworks smartcard (id 4372576f)
13:20:52.729: systems: registering CA system SC-Nagra, pri -10, ident 1006
13:20:52.729: registering Nagra smartcard (id 4e616772)
13:20:52.729: systems: registering CA system SC-NDS, pri -10, ident 1007
13:20:52.729: registering NDS smartcard (id 56694732)
13:20:52.731: Monitor listen on port 50965
13:20:52.764: B:Betatunnel, CAID:1833 with Provider:00000000 to CAID:1702 with Provider:00000000
13:20:52.764: Engine [MD-API]
13:20:52.764: loading smartcard data from C:\Program Files (x86)\DVBLogic\DVBLink\sources\TVSource-2\plugins\smartcard.conf
13:20:52.765: loaded 5 smartcard data from C:\Program Files (x86)\DVBLogic\DVBLink\sources\TVSource-2\plugins\smartcard.conf
13:20:52.765: loading cardclient config from C:\Program Files (x86)\DVBLogic\DVBLink\sources\TVSource-2\plugins\cardclient.conf
13:20:52.765: ** registered systems:
13:20:52.765: ** SC-NDS (pri -10)
13:20:52.765: ** SC-Nagra (pri -10)
13:20:52.765: ** SC-Cryptoworks (pri -10)
13:20:52.765: ** SC-Conax (pri -10)
13:20:52.765: ** SC-Viaccess (pri -10)
13:20:52.765: ** SC-Seca (pri -10)
13:20:52.765: ** SC-Irdeto (pri -10)
13:20:52.765: ** Cardclient (pri -15)
13:20:52.765: COM3: open serial port
13:20:52.785: COM3: set serial options: 9600,SM_8O1
13:20:52.787: smartcards: added serial port COM3 as port 0 (normal CD, normal RESET, CLOCK 3571200)
13:20:52.787: 0: new card inserted
13:20:52.787: COM3: set serial options: 9600,SM_8O1
13:20:52.789: 0: reseting card
13:20:52.790:
13:20:54.540: 0: indirect convention detected
13:20:54.540: 0: atr decoding TS=3f hist=7 Y1=70 TA1=18 F=372 D=0.000000 TB1=00 TC1=00 N=0 Y2=00
0: historical: d3 8a 42 01 64 90 00
0: historical: '..B.d..
Blocked 2 same messages...
13:20:54.540: 0: atr checksum not given/not required
13:20:54.540: 0: indicated wwt(T0)=1000 ms, bwt(T1)=1600 ms (at 3.5712 MHz)
13:20:54.540: 0: Init Viaccess card
13:20:54.540: ReadIni: COM3_9600 default 0 now set to 1
13:20:54.540: 0: read baudrate from menu, baudrate 0 to 9600
13:20:54.541: COM3: set serial options: 9600,SM_8O2
13:20:54.542: card v.unknown
13:20:54.913: card UA: 312649919
13:20:55.312: provider FFF400 (ISSUER)
13:20:55.696: provider 030B00 (TNTSAT)
13:20:55.729:
Blocked 1 same messages...
13:21:21.532: Ch: 100 - TF1
13:21:21.532: Programm crc: 255C4CF5
13:21:21.533: PMT: ACamd_PMT.txt, search, found...
13:21:21.533: PMT: Index=2 PMT=0064 SID=2329 CAID=0500
13:21:21.533: PMT: Provider=00030B00 ECM=0500 EMM=0100 Name=TF1
13:21:21.534: 0x0064 0x2329 0x0500 0x00030B00 0x0500 0x0100 11111110
13:21:21.778: Incomming PackageSize [184]
13:21:21.829: provider not found on card
13:21:21.829: SC-Viaccess 0: ECM [0500][0500/00030B00] Pro (0.000)
13:21:21.829: SC-Viaccess 0: ECM [0500][0500/00030B00] not able to decode
