Welcome to our hobby and you are about to have a lot of viewing options.
Please do not post the same question in different forums as this leads to some confusion.
I have deleted your other thread.
The first thing you have to do is download the Cas Studio software, for your Cas programmer, at least I hope you have a Cas programmer as that is required to program your Diablo Cam, you can find it here:
_http://www.duolabs.com/casstudio.html
Do not connect your Cas programmer until after you have installed the drivers, it makes it easier for your computer to install them.
Once they are installed connect your Cas programmer to your computer using just the USB cable, this is all you require.
Next you need to download the latest Underworld file, this is currently underworld 136, just type underworld136 into any search engine and you should find it, or look in our forums Links Section.
Once downloaded, and uncompressed, you might need winzip, or winrar, to uncompress it or you can use the free 7-zip software, copy underworld136.dup to your computer desktop, as it makes it easier to find for programming.
Programming the Diablo is quite easy:
Insert your Cam carefully into the Cas programmer.
Start up the CIS 8.5c software, you should have a shortcut icon on your desktop.
Click on the Cam Module tab, and the 2 Diablo Cam icons, this starts up the Diablo software.
It should automatically be set to the Upgrade Cam tab.
Click on the little icon, with 3 dots, at the end of the File Name: address bar.
Navigate to your desktop, underworld136.dup and click open.
A green light should now appear on the Start Update icon, click this and wait for the Cam to finish programming.
Once complete click the yellow Exit icon, this will bring you back to CIS 8.5c.
You now need to adjust the configuration settings.
Click on the Utilities tab, and the Common Interface Host icon.
You should now see underworld 136 displayed, click enter.
Enter the Configuration folder and change the following:
Emulators to ON.
N2 AU to ON.
Emulators priority to 1 Emu 2 Card.
Once complete exit the software and remove your Cam.
With your Cam programmed you can currently open the following main packages:
Premiere 19E
DigitAlb 16E, except the HD channels.
Polsat 13E
Digi TV 1W
Canal Digital 1W.
For full details of allt the channels available, on these packages, copy and paste these links into your browser, minus the underscore _
_http://www.lyngsat.com/packages/premiere.html
_http://www.lyngsat.com/packages/digitalb.html
_http://www.lyngsat.com/packages/polsat.html
_http://www.lyngsat.com/packages/canaldigital.html
_http://www.lyngsat.com/packages/digi.html
That should provide you with plenty of viewing options for live football, films and general entertainment.
If you have any problems please post back.
