I found specs in English. Here is the link -
http://www.altsat.be/engels.htm
Triple Dragon
499,00 €
Future expansions GENERAL FEATURES
Main processing components
CPU IBM PowerPC 405
RAM 64 MB for operation system and applications
16 MB for graphical subsystem (frame buffer)
ROM 8 MB Flash EEPROM
Tuner
Input 1x F-Connector
Output 1x F-Connector
Input-/Output-Impedance 75 Ohm
IF-frequency range 950 - 2150 MHz
IF-signal level -65 to -25 dB
Channel Bandwidth/td> ariabel 10 - 30 MHz in steps of 2,5 MHz
tuning system PLL-Synthesizer
minimum tuning step size 125 KHz
PLL-Lock time typ. 20 ms / max. 50 ms LNB-Supply voltage 14 / 18 V
max. LNB-Supply current 400 mA
LNB Control-signal 22 KHz / 0,6 Vpp
Demodulator
Modulation types QPSK (DVB-Systems), BPSK (Software not finished) (DSS-Systems)
Symbol rates 2 - 45 MBaud
FEC DVB: 1/2, 2/3, 3/4, 5/6, 7/8
DSS: 1/2, 2/3, 3/4, 5/6, 6/7
MPEG Decoder
Video MPEG-2 according ISO/IEC 13818-2 MP@ML
MPEG-1 according ISO/IEC 11172-2
Audio MPEG-1 / MPEG-2 (Layer I and II) and MPEG-1 Layer III (MP3)
Audio-/Video In-/Outputs
combined In-/Outputs 2x Euro-AV (SCART), therefrom:
- 1x TV-Out with RGB/YUV (optional with Sync on green),
Composite Video (CVBS) and stereo Audio - 1x Aux-In for RGB,
1x RF-Out (UHF-Modulator Software-controllable)
Video In-/Outputs 1x RCA (Cinch) Composite Video Out (CVBS)
1x RCA (Cinch) Composite Video In (CVBS)
1x Mini-DIN (Hosiden) S-Video Out
Audio In-/Outputs 1x RCA (2x Cinch) stereo Audio Out
1x RCA (2x Cinch) stereo Audio In
1x RCA (Cinch) electrical S/PDIF digital Audio Out
1x Toslink optical S/PDIF digital Audio Out
Data In-/Outputs
Netzwork 1x RJ45 100 Mbit/s Full Duplex
USB 1x Typ A with optional cable adapter
Systembus 1x 50-pin Mini-Sub-D Connector for DVR-3000
IDE 1x 40-pin ribbon cable connector for additional hard disk
Pay-TV
integrated 2x Cardreader licensed for Conax. Other systems on demand and necessary licensing
Common Interface 1x Slot for CI-Modules
User interface
Global OnScreen Display OSD an TV and LC-Display
OSD-/LCD-Languages English, German, Greek, Italian, Norwegian, Polish, Russian, Slovak and
Turkish
Channel management
storable channels depending on the channel name length between 6000 and 8000.
With reconfiguration of the memory management even more possible
Favorites unlimited, free editable
Channels search per satellite automatic all configured satellites, choice of configured
satellites or one satellite.
User choice storing all Channels or only free to air channels
Channel search per transponder yes, by input of satellite- and transponder relevant data
Antenna control
Mini-DiSEqC yes
DiSEqC 1.0 yes
DiSEqC 1.1 yes (Software not yet finished)
DiSEqC 1.2 (Rotor) yes
USALS (Rotor) yes (not yet certified)
12V Relais yes, also in combination with DiSEqC/USALS
LNB-Power for polarity control or switched off fur special purpose configurations
C-Band reception yes
VIDEO OUTPUTS
RGB yes via SCART-connector, no YUV if RGB is selected
YUV yes via SCART-connector, no RGB if YUV is selected
S-Video yes, dedicated output Mini-DIN-connector
Composite Video (CVBS) yes, dedicated output Cinch-connector and SCART-connector
HF-modulated yes, UHF channel 21 to 69, controllable by software
Videoformats
50 Hz Systems PAL-B/G/H, PAL-N, PAL-I, PAL-K, S*caM-L/D/K, S*caM-H
60 Hz Systems NTSC-M, PAL-M
Picture aspect ratio
4:3 yes, in this case 16:9 as letterbox or zoomed
16:9 yes, in this case 4:3 with vertical borders
automatic 4:3 / 16:9 yes, signalling to the TV via SCART-switching voltage
Audio-Options
Dolby Digital AC3 yes, if available to the channel. Bitstream out to S/PDIF-outputs
DTS yes, if available to the channel. Bitstream out to S/PDIF-outputs
Electronic Program Guide EPG
Short Event Info yes, for current and next transmission while switching to the channel or
after request
Long Event Info yes, for all available transmissions from the channel by request
Teletext
Software-Decoder yes, according to Level 1.5 incl. Enhancements Cache 4000 pages
Character sets Latin including all national subsets, Kyrillic, Greek
Navigation systems TOP, FLOF and Cursor
Subtitles yes, also without knowledge about the page number via OSD
Software Updates
Medium via Network from a PC
from Windows-PC free Tool or every TFTP-Server-Software
from Linux-PC Linux-integrated TFTP-Server
Programming interface
Plug-in loadable from USB-Memory (USB-Sticks, ...)
Shipped parts
- Set-Top-Box
- Power cord
- Remote control
- printed user manual
- mounting-kit for hard disk, preinstalled with cables
backtop<STYLE="BACKGROUND-COLOR: rgb(0,0,0)?>
