TurkmenAlem/MonacoSat 520E (52.0°Ε)
First test carriers appeared 20 minutes ago: 10722V and 12459V (the first and the last transponders?)
Both carriers used in wide-band mode, maybe modulated
Test carrier 10723 V and 12456 V
11304 H, 11421 V and 12418 V
11303H, 11421V, 12418V
All in orbit tests will have been completed on 31 of May 2015.
Into the next ten days of June, the satellite will be delivered by constructor "Thales Alenia Space" to Turkmenistan authorities.
Test carriers 10803V, 11380V, 12226V, 10843V, 11421V received yesterday
Test carriers 12284H, 12456V, 11303H, 11380H, 12418V
A lot of test carriers received today:
12226V, 12264V, 12245H, 12399H, 12284H, 12437H, 12360H
12303V, 10880V, 11400V, 11220H, 12380V, 10723H, 12456V, 10803H, 10760H
10840H, 10925H, 11340H, 11420H, 11250H
Again a lot of test carriers were on May 21:
11345V, 12284H, 12322H, 12264V, 12303V, 12341V, 12380V, 12418V 12456V, 12226V, 12245H, 12360H, 12399H, 12437H, 12476H, 10760H, 10720H, 10803H, 10845H, 10880H and others.
Sometimes I had received upto 7 test carriers simultaneously.
Additional spectrums
More spectrums
More spectrums
I created a provisional frequency plan, the combination of data that I own with the frequencies tested...
I actually used a ruler at the LCD display to determine tempo's carrier frequencies!
In low band, 36 MHz transponders separation seems 41.5 MHz, for 33 MHz transponders seems 38 MHz.
10719.5 - 10761 - 10802.5 - 10844 - 10885.5 - 10927
11219.5 - 11261 - 11302.5 - 11342 - 11380 - 11418
This grid better fits tempo's findings. May be offset a bit of course, depending on his LNB offset.
11343 V very good signal on my 88cm :)
This grid seems to be close to real. For example, I have measured active at the moment TPs :
11220H+V, 10929H, 10845H, 10761H
Offset of my LNB is about +2 MHz to the most of frequencies posted by another people.
