rolfw said:Yes if you can a) receive the satellite (have a big enough dish) and b) get hold of a card.
sashi002 said:what about watching those german channels outside of germany? does the premiere card work there?
Turok said:Hello!
where are you located?
when you are from dubai,like i read in your profile,then i dont think that is posible to reive the sky germany channels?
the signal is stronger,since the change of the satellite,in greece and other areas,but not in dubai!
Analoguesat said:The premiere card will work anywhere inside the coverage area with an appropriate receiver. The UAE is probably too far east to get coverage though.
i dont know the size of the sat as every building here has a common one unless i do apply a provite one but am not sure if i can find astra here!HB13DISH said:What is your dish size?
I believe that many of the Sky Germany channels can be received with a relatively not so big dish (1.2-1.6m) in the UAE.
Check the channels under the Wide beam from 1M.
Why don't you point your dish (whatever size it is) to Astra 19.2E and see which channels you can see after scanning?
You can then worry about how to get a subscription card.
_http://www.lyngsat.com/astra1m.html
_http://www.lyngsat.com/packages/skydeutschland.html
Report back if you can, as this can help others living in the ME.![]()
