New Version:
VMA Stream Reader
- First feature complete version
- Correct DX reports for terrestrial modulations
- Bug fixes
With this version I consider the software "finished", apart from possible bug fixes and optimizations.
I believe I added all required features:
- Support for DVB-S/S2/T/T2/C/ISBN-T (I don't own a compatible TBS device that is ATSC capable)
- Frequency based blind scan (the user inputs the frequency)
- Spectrum based blind scan (the used double-clicks the spectrum)
- Automatic Blindscan using 2 methods plus optional additional search algorithm
- DX reports (spectrum based and list based): these can be saved and loaded
- Automatic comparative DX report (comparing new/lost transponders: first against last or each against previous)
- Long term signal monitoring
- Spectrum measurements
- Support for external spectrum analyser (SMA/NWT4000 and Siglent SSA series)
- Support for TBS6903X (and similar cards)
- Transponder list export
- Streaming of the locked Transport Stream to external applications - preferrably VMA Transport Stream Analyser
- Support for UDP and TCP streaming
- Satellite management with automatic tuner selection
- Possibility to load different streamreader.dll versions
- Full Log
- (Incomplete) visual accessibility features (speech output)
