dreamsat
Specialist Contributor
- 2,20m Kathrein, 3,7m Andrew, KU,KA,C,C-Ext. LNBs
- germany
I just got an X-Band LNB from SMW to test here. Frequency range 7250 - 7800 GHz. The LOF is 6300 and the frequency stability is +/- 1ppm.
I made a Feddrohr and made a dielectric for it. This setup is currently used in the 2.20m antenna. At the weekend I will optimize the feed and the position of the dielectric.
I will publish reception results here.
