X CAM with cas 2 deluxe & funcards
radedef
Hi there!
Does anybody know where I can find a decent guide on to how x-cams are programmed? 1) with a cas 2 deluxe programmer (via USB port if possible)
2) through 2 funcards 6?
Any help would be greately appreciated!
radedef said:
Hi there!
Do you have the CAS Interface 2? If you have that then its very easy. Just download the software from the duolabs website, install the driver following the instructions and you will also see instructions on how to programme the X-CAM. Its very easy.
radedef said:
Hi there!
You need the cas2 add-on to program xcam, you can't do without it!
