YoutubePlayerE1_Final
IMPORTANT for dm7000 and dm7020 : Please use the attached
YoutubeplayerE1_70x0. This version only works with vlc 0.8.6.
Works with both vlc 8.6 and vlc 9.8.
Possible to select video from different Regions - GB, DE, IT, RU (Russia), PL and others.
Possible to select Time-span for videos - from today, this_week, this_month and all_time.
Possible to edit the vlc server-ip (with remote) or select from list.
Install plugin :-
The plugin will ask for libcurl.so.3 with some images and libcurl.so.2 with others. But the attached libcurl.so.2 will be ok - change the name to libcurl.so.3 (when asked for) and ftp to /usr/lib (for openembedded images) or /var/lib (for others) and chmod 755.
The plugin .so and .cfg to /usr/lib/tuxbox/plugins (for openembedded) or /var/tuxbox/plugins (for others) and chmod 755 for the .so.
The .xml file to /etc/tuxbox/config (for openembedded) or /var/tuxbox/config (for others). Edit to insert the pc-ip.
Configure vlc 8.6 :-
Settings - Preferences - Interface - Main interface - select HTTP.
Settings - Preferences - Interface - Main interface - HTTP - Advanced options - insert in Host address :8080.
Close and restart vlc.
Configure vlc 9.8 :-
Tools - Preferences - All (at the bottom) - then same steps as for vlc 8.6.
Preferences - Stream output - select (tick) all boxes except 'display while streaming'.
Open program folder VideoLAN (default install C:\Program Files\VideoLAN). In VideoLAN\VLC\http and \VideoLAN\VLC\http\old find two files .hosts. In these files find lines like :
#192.168.0.0/16
Delete # and insert the pc-ip (vlc server-ip). Important to do this in the two files.
Important when uninstalling another vlc version - also select option to delete preferences and cache.
Tested with :-
VLC media player version : 0.8.6a and 9.8.a
Windows os : XP Pro
Dreambox image : Gemini 4.60
Dreamboxes : 600pvr and 5620.
(If it works with other setups - please post).
Enjoy.
Regards, pcd.
Install plugin :-
#192.168.0.0/16
Tested with :-
Windows os : XP Pro
Enjoy.
Regards, pcd.
