Advice Needed Channel Master 1m20 C-band mod
True but I dont like touching elevation controls for obvious reasons, although its just 2 nuts on CM..
Well, if you fit a jack on and add another V-Box on top then it will be easier than having to do it manually. Technically the C band LNB will be not be at the dish's focal point but C band is more forgiving than Ku.
Having motorised elevation also means you can fine tune the dish better.
Inverting the reflector prevents water from getting in the feedhorn.
You could go 'old style' and find a CoRotor and some flanged LNBs.
You will need a pulse generator to drive the internal motor
Speaking about size of clamp for C-band LNB, it should be 65mm (not less), as the majority of C-band LNBs has 65mm neck size. Some LNBs, like Chaparral have even bigger neck diameter.
Many thanks for all the feedback.
With the advent of Ka-band transmissions covering our are more and more, it would be nice if someone offered a Ku+Ka band LNB.
Curently, Ka band LNB are very expensive.
I also got hold of a Chapparal borehole C+Sband feed for a 3m parabolic.Seema hard to use it though.
I am already motorised uasing an 18-in arm and Pace 995.
There is not much out there on S-band (Es'Hail 2 uplinking)
I doubt the Pace has the components to run a mechanical polariser
Combi LNB I will have is H/V switching by voltage, for both Ku and C. Not sure it will give optimum performance on C band.
The combi LNBs should be OK for C band, it's the Ku frequency that will be lossy.
Unfortunately, you may be right .The Chinese manufacturer does not give any technical info on gains or cross-interference etc.
about ten years ago I installed an LNB band C (with modification to avoid the scala ring) on my channel Master 1.20 offset from the focal point, on 40° East there was good reception.
I’m looking for information about this modification to avoid scalar ring, someone still using this ?
Which specific post on this site ?
The post from @stephan94 (#4) there's a specific feedhorn on his C-BAND lnb:
That is possibly a polyester lens, similar to the 2 degree bullet LNBs.
I have previously mentioned the Prodelin prime focus dishes do away with the scalar rings on c band option.
