neumoDVB
I have the bin executable in neumowxsvg, but it doesn't open. It says tiger.svg doesn't exist.
Obviously as the name of the downloaded file is different.
~/neumodvb/build_ext/neumowxsvg/bin/svgview Awesome_Tiger_Icon.svg
Maybe I can try it in Fedora, which doesn't have any issues with overlaying.
Yes, try. It will work, if you use the correct command line
Also, an assertion error in cachyos - /usr/src/debug/wxwidgets/wxWidgets/src/gtk/bitmap.cpp(595): assert ""image.IsOk()"" failed in InitFromImage(): invalid image
This may or may not be related, depending on when the message appears.
In Fedora, after uploading the code, there's nothing in build_ext/neumowxsvg/bin except the existing svgview file. Just this connect error -->
davidl@fedora:~$ wget https://upload.wikimedia.org/wikipedia/commons/f/fd/Ghostscript_Tiger.svg ~/neumodvb/build_ext/neumowxsvg/bin/svgview Awesome_Tiger_Icon.svg
Failed to parse URI '/home/davidl/neumodvb/build_ext/neumowxsvg/bin/svgview'
Failed to resolve 'awesome_tiger_icon.svg' (Name or service not known)
Failed to connect: Connect error
Saving 'Ghostscript_Tiger.svg.1'
HTTP response 200 [https://upload.wikimedia.org/wikipedia/commons/f/fd/Ghostscript_Tiger.svg]
Ghostscript_Tiger.sv 100% [=============================>] 21.90K --.-KB/s
[Files: 1 Bytes: 21.90K [65.20]
You seem to have creates one non-working command from 2 separate ones....
First the wget. Afterwards the svgview
Still a problem with the two seperate commands.
Saving 'Ghostscript_Tiger.svg.4'
HTTP response 200  [https://upload.wikimedia.org/wikipedia/commons/f/fd/GhostscrGhostscript_Tiger.sv 100% [=============================>]   21.90K    --.-KB/s
                          [Files: 1  Bytes: 21.90K [136.0]
davidl@fedora:~$
davidl@fedora:~$ neumodvb/build_ext/neumowxsvg/bin/svgview
../src/gtk/bitmap.cpp(595): assert ""image.IsOk()"" failed in InitFromImage(): invalid image
You still did not execute the commands I requested. Don't start improvising.
Your last command does not specify and image, so of course it fails.
If the tiger does not appear, then you can also try some of the things listed here:
OK, back to this after a weekend break.
Cachyos. I do have the tiger image after correctly placing it in the neumowxsvg directory.
davidl@mainPC bin]$ wget https://upload.wikimedia.org/wikipedia/commons/f/fd/Ghostscript_Tiger.svg
--2026-09-28 19:18:20--  https://upload.wikimedia.org/wikipedia/commons/f/fd/Ghostscript_Tiger.svg
Loaded CA certificate '/etc/ssl/certs/ca-certificates.crt'
Resolving upload.wikimedia.org (upload.wikimedia.org)... 2a02:ec80:300:ed1a::2:b, 185.15.59.240
Connecting to upload.wikimedia.org (upload.wikimedia.org)|2a02:ec80:300:ed1a::2:b|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 68630 (67K) [image/svg+xml]
Saving to: ‘Ghostscript_Tiger.svg’
Ghostscript_Tiger.s 100%[===================>]  67.02K  --.-KB/s    in 0.02s
2026-09-28 19:18:20 (3.62 MB/s) - ‘Ghostscript_Tiger.svg’ saved [68630/68630]
I'll check your other options. Not confident about being able to do anything in the neumo log though.
