Hi!
my dish,2,40 echostar mesh installed last week,,you are right horizont are very deep 6,78 degrees, here ,only on roof i have free sky,this makes the installation very dificult,need 15 cables 9 for the dual axis,and the rest for the chappral corotor,now i must wait,to borow,a signal meter,from a coleague!
the 3863 is the strongest,but i could have the problem,that the polarizer of chapparal takes some db,but the most bigger problem,in east direktion,trying with normal lnb,the antenna is so high on roof,that i need a 15 meter long leader,to set up the skew,then i would have no lost,in db without using polarizer,maybe,this db that the polarizer takes,is enough,that signal is not strong enough
aproximently 5 db...
with sensitive tuner it should work!
if not,i will ,chancel,my hobby forever
