Aerial & Satellite Installer Wirral,Merseyside
UK Sat Online
Supporting Advertiser
Sky Hd
2mb sometimes works broadband but most of the time is faulty
1.2metre dish with technomate 6800 sitting in shed will go up a some point
wirral
Aerial & Satellite installer covering Wirral & Merseyside
Domestic and commercial Aerial and satellite systems.
Aerials: new installations, extra points, TV link upgrades, repairs and troubleshooting.
Satellite: Authorised Sky seller/installer, Re-alignments, fixed dish installs, Motorised/multi lnb installs, freesat
Audio/Video: Surround sound setup, TV wall hanging, Hi Def distribution,
Also system design for Diy available
How much will it be for a motorised dish install I can't PM so i'll have to post here thanks
You should be able to PM.
Hi mate, iv got a technomate 1500i super with motorised 90cm dish all setup but havnt used it for a while, how much for u to align it and set up for 1W cheers
Have a complete satellite set-up, just changed the receiver to a Humax Ci2000 for HD reception, need the box setting up, programming and "V" box installing. Previous receiver was a Echostar 3000 ip. Dish will probably need tweaking as I want to get other satellites. Please phone (phone number removed, please don't post on open forum)
I am looking to get a 90CM dish with motor attached to the wall and aligned. House is near the front on West Kirby, from my checks it seems to have a good arc from fairly far east to west with no obstructions. I can't send PM's so please could you give me an idea on cost or how to contact you to discuss. Thanks.
[fieldset=Admin]you should be OK to PM now[/fieldset]
HI, how much does it usually cost? does it depend per area? or are there any difference? thanks. ;)
Hi, I am looking for someone to install a motor on an 90cm triax dish and also fit a digital aerial. I am located on the wirral. Cheers
Hi M8,
Your pm's needs activating,send me your email,may help you...
MARK said:
Hi M8,
I have activated dayion's PM
I am looking to get a fully motorised system DM8000 with the andrews 1.2m dish installed can you please quote
Dont see any option to PM :confused:
You have to be a member for longer than a few hours to have PM privileges due to previous abuse by new members. I have however enabled it for you to allow contact with the original poster.
how much would it cost to set up i have come to the conclusion that my knowledge either of computers or sattelite equipment is not good enough thanks:-worship:-
Listing what else you require installing will be useful in allowing someone to quote you, for example dish motor lnb etc what satellite/ satellites you want it setting up for and of course what you are expecting to be able to watch?
will need to speak to you in the new year cant afford new dish motorised or not at the moment i dont think i can send pm will find your phone no and get in touch to see what my options are thanks
We are not allowed to give out contact numbers or links to our websites publically on here so when your ready if you ask Rolf very kindly he should be able to allow you to pm people
