Approved Repairers
Shireoaks1616
VU=uno 4K SE
UK
Hi guys I have a VU+UNO 4L SE Sat box . My box was working ok and I went away for a weeks holiday when I came back I noticed that the dispaly was showing the incorrect time. I closed the box and powered down and left it for a few minutes and then I re powered up the box , but nothing will load the front screen is showing just scrambled lines. I have been told that I need a new mother board, really disappointed because this box is only about 3 years old. The selling company is no longer in buisness . So my question is does anybody know where I can send my box to get it repaired or can give me details on how to contact VU+ directly.
Would appricate any help
Possibly the switch mode power supply in the box, these are more likely than the motherboard to fail I would say. Has it mains straight to the box, or a separate power unit? Try another power supply if that is the case first.
Have you asked your neighbours, to see if you had a power cut, while you were away?
I assume that it is a VU+ Uno 4K SE, and the L is just a typo?
Have you tried loading an image, from a USB stick?
http://www.vuplus.com/sub/main.php
Support, from VU+ seems rather suspect, so it might be better if you can find someone who repairs computers, and has test equipment, to test your motherboard, and power.
Neighbours from three doors down.
