Hi! Finally I got a DM8000 yesterday, but as usual it appears problems.
When I try to add the flash on the DM8000, it does not accept the IP address. It does not arrive any IP to flash via webinterface. I have tried DreamUP, but it says: "Files not found"
It looks as if there is any problem with the image (1.7 nabilo), it does not update. In the network settings, it says that IP is not available, but it is connected to the router.
Can anyone help me? Thank you, I appreciate every single suggestion
