Advice Needed Complex setup - rotor and T90 with a multiswitch
Robinson74
Motorised dish 45E - 30W, Clarke-Tech ET9000
Poland
Hello,
Can you please help with extra equipment I need to make the most of this setup?
The most important is Box 1.
The red line is a cable which additionally supplies power to Moteck 2100 rotor. It is preferred to control the rotor using Box 1. All boxes are Mutant HD 51 with 2 single DVB-S2X tuners.
I understand I need some clever DiSEqC switches which can pass current to the rotor.
If it is a problem I can eliminate the terrestrial antenna.
Hello,
Since you are using twin input tuners (as I have done before now) there should be no confict anywhere, apart from identifying which receiver drives the motorised dish, in which case you should turn off DiSEqC 1.2 continuous repeats on the other two.
For terrestrial just diplex out at each room socket
