DS9
  • Thread starter Thread starter onuroral
  • Start date Start date
O
onuroral
Guest
I have a quad card. The one with the two pic and two eeprom socket. Is it possible to replace the chips and use the same card for DS9. If not is there any place that I can find a pcb drawing for the card and the programmer. Thanks
Onur
Sounds like a lot of work turning your card into a silvercard because the ds9 version 5 uses the pic16f876. This chip has alot more legs (28 in total. 14 each side).
See my post http://www.satellites.co.uk/scripts/webforum/DCForumID15/404.html
If you go to http://www.volny.cz/osepie/ you will find all the information you need to make a piccard2.
nobbly :+
