EBSPRO Favorites TPs and Windows11
Max2000
satellite lover
DM 920HD + Toroidal dish with 13 inverto ultra lnbf + Laminas 1.80m with smr1224 AZ/EL dualfeed C/KU invacom lnbf/Titanium C-band lnbf + 8ft dish with jaeger 36" actuator and Titanium C-band lnbf (58W - 78.5E)
increasingly eastward...
Recently, given the times we live :cool:I decided to update my equipment to a new pc with windows 11 operating system.
(I still was with windows 7).
No problem at all and finally I install my TBS6908 that was immediatly recognized and worked perfectly.
But I've seen I have an odd problem with EBSPRO favorites tps.
When I add manually a new favorite (EBSPRO version 18.0.0.4) it seems program can't save it correctly :(
And favorites list remains empty :unsure
Other lists as old blind scan results are perfectly shown.
So finally favorite page tps don't appear making them not available for further check in the right window of the program.
I try a different TBS card too, but such problem continued.
Do anyone have the same problem or a suggestion?
Luckly after thousand of test I could solve the problem by myself :Y
I'm posting the brief info, in the case anyone in future could match a similar problem.
Basically when I reinstalled the new versions of EbsPro or after each past pc formatting, I was used to copy the old database in
ebspro config in appdata/... folder (so I always had old scans and favorites with me).
But for some reason it didn't work correctly anymore with the new system.
I realized about the problem, because during my satellite scans I found a satellite where the old favorites where still
correctly stored :rolleyes:
So problem could be in database that had been taken by my old config with profiles and ranges folders.
Once I deleted the nonessential files and restarted the program configuring again the basic missed service lost
(tsreader,vlc...), after the scan favorites could be added correctly :-clap
That's all :cool:
Test with EBSpro to run directly with VLC the Italian and French programs on MIS PLS transponders at 5.0W using DVB cards on the Montage m88rs6060 chip based DVB cards based, i.e., tbs6902se/6904se.
