elvis with goldcard
jcdavo
pj::
i have a humax5400 patched with 3.2 using an elvis running on mp6 using goldcard but no files i try seem to work ?? what is the name of the file i need and in mp6 do i just press outodetect then when it comes up prodject then under pic and under eprom do i just highlight pic then hit open then click on the one pic file then do the same with the eprom then on the top toolbar press program wait about 30 seconds and thats it , i,v done this about ten times but no luck with channels?an i doing something wrong ram i using the wrong files have tryed *****via,irseca,viamax and many more , many thanks jcdavo
what message is your receiver displaying?,have you tried using Dosprog 2.4, select the type of card you are programming from the list,select the Pic file, then the eeprom and then program. what type of wafercard are you using.You need to be more specific,it might then be easier to figured out what you are doing wrong.
Regards
Prince
