Sold EMP Centauri ms5/bplp-3 8 way receiver powered multiswitch
I purchased this with the intention of installing it in my dads house. My dad has decided to go down a different route so its no longer required. Its is brand new and unused.
You will need a Quattro lnb to use this switch, it will not work with a quad lnb
5 inputs, 1x Terrestrial & 4x Sat (VL, VH, HL, HH) with 8 outputs.
The switch is powered by the satellite receiver but can be powered by an external 12v power pack (not included) External supply is not to be used if terrestrial input of the multiswitch is DC-shorted (eg. by balun)
Frequency range LNB inputs 950-2300 MHz
Terr. input 5-862 MHz
Outputs 5-2300 MHz
Control 13/18 V + 0/22 kHz
Insertion loss Sat. 3 dB
Terr. 16 dB
20 dBSat. inputs isolation
Maximum input level* Sat. / Terr. 90 / 100 dBµV
Maximum output level* Sat. 87 dBµV
Terr. 84 dBµV
Power consumption From each receiver 55 mA (18V)
Dimensions (w,d,h) 13.5 x 10.4 x 4.1 cm
£10 all in, Payment by Paypal Gift or Bank Transfer.
