Hello, i need help finding names of radio stations at 12580H468 or 469. I guess this frequency is similar 39e 11088e i cannot receive it so not sure. Anyway i recorded full tp and use MPC or any other player to listem to radio and switch tracks... I used hex view but nothing was found.
TBS 6903 is not good for low frequencies so it is hard to lock it every time for me.
1.The names of these French radio on 12581 H you find on FlySat,and if you want to listen to each radio post,you must choose audio track 1,2,3 or 4.You can download from
here I recommend to use Potplayer.
2. Trp.12581 H at 12.5 W is not similar with 11088 V on 39.0 E,because the first is a standard transmission,which means that you choose the audio track in your application(ex.potplayer),while the latter is radio IP,i.e you must decode/extract each radio stream individually.At 11088 V from 39.0E we have a package of polish radios ip.
Here's what it looks like each audio stream after decoding:
You can
listen each stream separately.
3.TBS6903 card lock the symbol rates as low as TBS6983!Her performances are similar with 6983,but provided to have a strong signal.
Here are some examples from 10.0E,16.0E,23.5E,12.5W and 30.0 W:
