Just Sharing This Glamour Aura FHD skin vB.5 for OpenATV images
With great pleasure, I finally present publicly my latest project, which is none other than my new skin called Glamour Aura FHD-ATV. It's a labor of more than a year in the making and testing!
Glamour Aura FHD-ATV (GAFHD-ATV) is a Full High Definition and High graphic resolution Premium skin for receivers running Enigma2 and the recent OpenATV images.
Due to it's high resolution graphical nature, GAFHD-ATV was designed and optimized to run on new generation receivers. The minimal requirement is an STB with a CPU of 1000 Mhz (3000 DMIPS).
GAFHD-ATV is also a skin you can contribute to. The ipk of the skin is distributed with closed converters/renderers, but all the python code along with the skin code is available on Github.
You can find the source code here: https://github.com/MCelliotG/GlamourAuraFHD-ATV-skin
You can pull your requests, make recipes for it and I will push contributions after testing.
GAFHD-ATV on par with its graphical user interface is fortified with an extended python system that runs along with OpenATV's enviroment, providing it with some exclusive new features.
SCREENSHOTS and extended features presentation
1. Main Infobar
The main infobar is divided into two sections. The top section contains all frequency and signal info. GAFHD is the first skin that fully supports real-time info for Multistream services, showing MIS info when such a service is tuned. Up to 12 tuners can also be displayed. The left top part is a weather panel which shows today's weather. Weather info requires the MSN weather plugin to be installed and configured (instructions will follow).
The top infobar will also display full stream URL and stream type when a service is stream.
The lower section is the main infobar which contains along with the program info, an extended service info icons panel, including icons for audio/video codecs, a full exact framerate display, and a short weather panel which shows the current weather condition. GAFHD can also display a live bitrate if the bitrate plugin is installed and configured (this will be explained below as well).
The lowest part of the main infobar is the extended encryption info. GAFHD uses a new detection feature which shows all available caids and encryption system names of a service.
NOTE: The skin works best with 400X240 picon size.
2. Second infobar
The second infobar brings an amplitude of extra information for both the service and the system layout. The weather panel shows additional info on tomorrows weather.
The left panel is the layout info showing real time CPU work, temperature, speed and load and internal HDD temperature. The upper layers show the pids of the service in decimal format and also real time info on connected storage devices, memory and swap.The middle part displays now and next program extended description.
3. Channel selection screen
Channel selection along with the service list on the right displays the extended program description on the left, the five following events and also a new transponder info panel which also shows the stream type and stream url on a stream service and transponder info for the rest.
4. EMC player infobar/EMC main screen
Media player will additionally show icons for resolution, audio/video codecs, subtitle availability and the exact framerate of a video or stream.
5. Info screen
Info screen along with the usual info also displays the HDD storage panel, which shows connected devices space both internal and network HDD and USB. The storage panel is also available on the HDD screens.
6. Language selection
GAFHD is a truly multilingual skin. It utilizes the new Aura new font I created based on Roboto and Noto fonts the skin is able to show Greek, Cyrillic, Arabic, Hebrew and Georgian among others. More alphabets can be added by request.
7. OpenATV screens (Blue panel, Network panels etc)
GlamourAuraFHD-ATV has been fully optimized for use in the OpenATV environment. All individual screens have been skinned for the maximum user experience!
INSTALLATION INSTRUCTIONS:
1) Download the ipk of the file.
Send the file to /tmp your receiver using an FTP program. Then you can install it manually via telnet or via the software manager.
Manually:
opkg install /tmp /enigma2-plugin-skins-glamouraurafhd-atv_B.5_all.ipk
2) FOR BITRATE INFO
The bitrate plugin is essential for bitrate to work. You can download it from the plugins menu.
For correct display in the skin it needs to be configured as follows:
mode: as infobar,
style skin: compact,
background window: transparent-black,
X screen position: 1645 ,
Y screen position: 0837 ,
Z screen position: 14.
The correct settings are also shown in the screencap below:
IMPORTANT NOTE: The skin works with the bitrate plugin, not with the BitrateViewer plugin.
3) FOR WEATHER INFO
The weather info requires the MSN weather plugin to be installed. I have included the ipk as well.
After installation you can configure your location via its settings menu.
Download MSN weather plugin from here (version 0.8-rc1):
MEGA
IMPORTANT NOTES/DISCLAIMER:
As stated above, GAFHD-ATV is a premium high resolution skin and is designed to work well ONLY for receivers with a CPU higher than 1000Mhz. This is an obligatory limitation due to the high resolution graphical nature of the skin which also makes the package large in size.
For receivers with slower CPUs use at your own risk!
Also, GAFHD-ATV for the moment will not work on any other images than OpenATV. This skin version was designed ONLY for OpenATV images. It's not guaranteed to work on other OE-A images.
Skins are also always in beta mode, as the development of the images continues. As OpenATV is available to a vast number of receivers, some features may not work as intented.
This piece of work with all its graphics has been licensed under GNU GENERAL PUBLIC LICENSE Version 3, 29 June 2007.
The code is opensource and available on github. You are encouraged to contribute in the skin's development, as long as it comes through Github's terms of use. You are allowed to make recipes and forked repositories.
Any modifications in the code has to respect the given licenses. The code is free to be modified ONLY for PERSONAL use. Unauthorized releases of the skin that void the license are not the author's responsibility.
The graphics of the skin are NOT allowed to be modified by third parties in any case, except for the author's consent.
Please respect the work of the skinner, skins (especially when created from scratch) take a lot of effort and time.
DOWNLOAD THE GAFHD SKIN IPK HERE:
VERSION B.5 (10/6/2018)
MEGA
I want to personally thank my beta testers for their feedback. I encourage developers to contribute to the skin's further development in github.
I really hope you enjoy my work!
Yes, they did changes on the skin paths. Please uninstall the skin completely and reinstall it from the feed, it's been fixed there. If it still does not work, I'll send you a version that does.
hi... hope thats fine....
i was using openpli images but now im working with openatv 7.3
i installed glamour aura skin...
also installed weathermsn from openatv repository but not appear on the image.. plugin working fine but dont see...
also i want to change the letter type... on openpli the great developer @MCelliotG sent to me the file with all letters types but on openatv not work...
any help for both problems
thanks
Yes, oaweather is in the fields.
hi master... thank you soo much for your help
now weather msn are working fine....
in the past you send a carpet/file with all letter types into it...
and on openpli i can transfer that file to etc/enigma2/glamour aura and the letter types changed... but on openatv dont working...
thanks in advanced if you can helpme!
what is the file location for posters in Enigma 2 please ?
Posters are automatically generated and their default location is media/hdd. If there is not such, media/usb should be mounted.
I don't understand why you want to manually change the font types. The main font my skin has is very high quality (and created by me) and has been calculated to fit exactly within the graphics. If you change to another font it's not a certainty that the font you want will fit correctly or even support unicode. Anyway, you can replace the fonts in the skin font folder but you have to rename them exactly to the names of the fonts that are already in the find. I DO NOT recommend this. Besides whenever there is a skin update, fonts will revert to the official ones.
thank you soo mucha for your help
