Lexzie
- Xtrend ET10000 DVB-C, DVB-S2, and IPTV
Dreambox DM920 DVB-C/DVB-S2X/DVB-T2
TBS 5925 USB-tuner
80 cm fixed dish (28.2E/23.5E/19.2E/13E)
180cm Channel Master offset dish with polarmount (39E-34.5W, Ku-band)
- The Netherlands
On f.e. Lyngsat you can see that on 12380 H two channels are present FTA, but without SID.
If I scan the frequency with TS Analyser they are not visible.
If you look at the other stations' PID's you can imagine what the SID, PCR- and PMTPID probably are for these two stations (above in red).
First I added the two stations with Dreamset, but Dreamset cannot add the PMTPID.
So, I edited lamedb (in stop-mode init 4) in this:
After init 3:
On both I have audio, but no video and the error message
Service not found!
(SID not found in PAT)
Any help in how to get these channels working?
Is there a tool which can read more data than TS Reader? It looks like the VPID shown on Lyngsat and Flysat is wrong?
Is the way I edit right? F.e. is c:16 right for adding the PMT-PID?
| name | SID | hex | VPID | hex | APID | hex | PCR | hex | PMT | hex |
| RTS1 HD | 461 | 1CD | 2200 | 898 | 2201 | 899 | 2200 | 898 | 2202 | 89A |
| RTS2 HD | 462 | 1CE | 2207 | 89F | 2208 | 8A0 | 2207 | 89F | 2209 | 8A1 |
| RTS3 HD | 463 | 1CF | 2214 | 8A6 | 2215 | 8A7 | 2214 | 8A6 | 2216 | 8A8 |
| BN2 | 464 | 1D0 | 2221 | 8AD | 2222 | 8AE | 2221 | 8AD | 2223 | 8AF |
| Pink | 465 | 1D1 | 2228 | 8B4 | 2229 | 8B5 | 2228 | 8B4 | 2230 | 8B6 |
| Al Jazeera | 466 | 1D2 | 2235 | 8BB | 2236 | 8BC | 2235 | 8BB | 2237 | 8BD |
| B92 | 467 | 1D3 | 2242 | 8C2 | 2243 | 8C3 | 2242 | 8C2 | 2244 | 8C4 |
| Prva Srpska | 468 | 1D4 | 2249 | 8C9 | 2250 | 8CA | 2249 | 8C9 | 2251 | 8CB |
01d3:00130000:000b:0001:1:0
B92
p:neosat,c:0008c2,c:0108c3,c:0308c2,c:1608c4,f:1
01d4:00130000:000b:0001:1:0
Prva Srpska TV
p:neosat,c:0008c9,c:0108ca,c:0308c9,c:1608cb,f:1
After init 3:
Service not found!
