Idiots guide to using dvbviwer
1> purchase and install dvbviewer software
2> download and install yankse in \MdPlugins subdirectory http://yankse.tforums.com/yankse/MDYankse-1-03.2- TT.zip (conax built in)
make sure subdirectory is named MDPlugins (MDP in capitals)
3> put softcam.key in the \MdPlugins subdirectory and in dvbviewer root dir (created using utility attached)
3> In the Filters directory, put regsvr32.exe (from Windows/System32), and drag and drop SkyAVC.ax to Regsvr32 to register it
4> put the channels.dat from SoftCSA (also attached) to the DvbViewer directory
5> ensure you have enabled Marfis Renderer
6> ensure you install softcsa attached in plugin directory
7> if you need ecm's they are in yankse.sid.cache in yankse zip
Off you go
Attachment: fun2md v2.1.zip
This has been downloaded 4 time(s).
Off you go
