You asked a question, it was a suggestion in case you might wish to watch/record something important.13ft from the washing machine 14ft with the brick wall in the way its not a laundrette.
In the UK, our houses don't have that option as each one only wired with a single phase of the local 3-phase distribution system.Try a different AC phase on the receiver.. Just use an extension cord and try different AC power plugs till you find one that reduces or eliminates the interference....
If that is only occurring on a specific channel, then it seems like interference from the machine to the receiver, and that's most likely to be caused by a radiated frequency-specific radiation "spike" from the machine flexible supply cable from the wall socket.Any idea how i can stop a washing machine causing interference to our sat dish. It gets turned on and causes breakup on Blaze channel.
I think all large white appliances in this part of the world have to be earthed via the plug, though there is a chance a fault has developed in the chassis, or cable.If that is only occurring on a specific channel, then it seems like interference from the machine to the receiver, and that's most likely to be caused by a radiated frequency-specific radiation "spike" from the machine flexible supply cable from the wall socket.
Therefore, if the machine is at all recent (like the last 20+ years!) , then it is probably breaching the radiated interference limits mandated by EU/UK legislation - and thus you should complain to the seller &/or manufacturer that it is not "legal"
OTOH, if all else fails, and from "another direction", pretty much every piece of domestic electronic equipment is, nowadays, not "earthed" via the main plug - thus adding an actual physical cable from the receiver case (assuming it's metal!) to the Earth pin in the mains plug may help to reduce the problems.
