It depends on the type of receiver you have. If it's patchable, you can download software to give you a code menu to allow you to update keys to open various encryption systems.Spir4 said:ah okay thx.
i have another question: is it usefull to patch your receiver, and if yes, why ?
Ar-Ey said:Hi 2 everyone.
Im in Saudi now and im planning to buy a new receiver.
what do i need to look for?...
damhy said:Salaam,
If your receiver only has irdeto on it then you will only be able to watch irdeto channels with it and a valid card. Which is why you need CI slots so that you can buy new modules that will work with other encryptions and also explorer the various developement modules ie. Dragon/Xcam/Matrix...
In theory any cam should work with any receiver. There some receivers that will not work with certain cams, but normally they will.Ar-Ey said:So this Dragin/Xcam/Matrix etc..are all of these compatible to any receiver that has CI?
As far as I know there are some encryptions that are hacked, this means that you can use them with a valid key, smartcard, or official card. All depends on what channels you want to watch and what is available. Dont forget that the number of channels from hotbird is very limited in the middle east, only those on the super wide beam will work and only those that are in available encryptions.Ar-Ey said:Is "Key" a substitute for smartcard?
I know that they are available in Bahrain, so I expect they are available in KSA also, the people that sell them would probably mainly sell to europeans that live in the middle east. So you'll have to ask about.Ar-Ey said:Are these cams available here?
I dont know too much about irdeto, i think that it is used by some dutch channels.Ar-Ey said:I have an Irdeto cam. Is it dirrerent from Irdeto 2 cam? or does this cam still have a use?
damhy said:In theory any cam should work with any receiver. There some receivers that will not work with certain cams, but normally they will.
