- TM 5402HD
Sky+ UK.
- Scottish Borders
Having raided the parts boxes again Ive started the new computer project. This one is for more occasional use than the previous build so no new cases for this one. Instead Ive found out the old computer base unit I bought back in 2000, stripped the psu & motherboard out and used this as the basis for the build. Its a beast of a case if a bit tatty round the edges!
The plan is to connect this one to a 145MHz dipole antenna mainly for use when the ISS is txing SSTV. Although it will also be used for experiments in decoding DAB which I havent tried yet and anything else which takes my fancy without risking upsetting the wxsat setup. (I have a nasty habit of disabling the auto frequency track & forgetting to re-enable it when Ive been playing with other stuff!)
New psu required of course so another VS550 as in the last build has been slotted into the case and Ive found an old hdd for it .. More details later.
