<newCSconfig>
<readers name="SCI">
<device>
<name>Lower Cardreader</name>
<type>sci</type>
<mhz>357</mhz>
<node>/dev/sci0</node>
<parity>odd</parity>
<reset>normal</reset>
<export>Yes</export>
<enabled>Yes</enabled>
<blocksa>No</blocksa>
<blockua>No</blockua>
<blockga>No</blockga>
<irdeto-camkey>0000000000000000</irdeto-camkey>
<irdeto-camkey-data>000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000</irdeto-camkey-data>
<crypto-special>No</crypto-special>
<ipk>000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000</ipk>
<ucpk>00000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 000000000000</ucpk>
<PTShandshake>No</PTShandshake>
<carddetect>yes</carddetect>
<newcamd_port>34000</newcamd_port>
<autosid>Yes</autosid>
<Seca-PPV>no</Seca-PPV>
<pincode>0000</pincode>
<priority>round</priority>
</device>
</readers>
<cache>
<emm>20</emm>
<ecm>-1</ecm>
</cache>
<debug>
<password>NewCSpwd</password>
<level>normal</level>
<type>init</type>
<output>console,tcp</output>
<console_options>normal,init</console_options>
<tcp_port>1001</tcp_port>
<tcp_options>normal,init</tcp_options>
</debug>
<newcamdserver>
<name>newcs</name>
<server-ip>Your_DNS_Host_Name</server-ip>
<deskey>01 02 03 04 05 06 07 08 09 10 11 12 13 14</deskey>
<user>
<name>Your_Dreambox_User_name</name>
<password>Your_Dreambox_Pass</password>
<hostname>Your_Dreambox_Lan_IP</hostname>
<port>34000</port>
<au>on</au>
<sidoverride>on</sidoverride>
<spider>No</spider>
<allow>lower</allow>
<rate>2</rate>
</user>
</newcamdserver>
<httpd>
<server>
<port>8080</port>
<enabled>yes</enabled>
</server>
<user>
<name>Your_Admin_User_Name</name>
<password>Your_Admin_Pass</password>
<accesslevel>admin</accesslevel>
</user>
</httpd>
</newCSconfig>
