Jorenas
- 60cm satellite dish, universal LNB, basic DVB-S2 satellite receiver, and a Windows PC. Currently setting up the system and learning about satellite reception and dish alignment.
- usa
The Inverto circular LNB was probably referenced as a comparison point because it uses a different receive/polarisation arrangement from the Norsat setup, so it helps separate LNB characteristics from the effects of the scalar, polariser, and waveguide transition. Your note about the H/V rotation bearings is also important: if the bearing or rotation mechanism is not holding the LNB precisely, even a small positional or angular error could affect the measured signal level and make the comparison less reliable.
