Lithuanian M-1 and M-1 Plius on Sirius
bite
Superkomanda
0.8W; 4.8E; 13E (90cm),
19.2E; 28.2E; 36E (110cm),
DM800SE, DM600
Riga, Latvia
Hello there...
Few years back I listened these radiostations (M-1, M-1 Plius) here on Latvia, because I'm living very near, to the lithuanian border.
But right now, the reception is impossible, because the local transmitters are broadcasting on the same (or very near) frequencies, as these radiostations.
So, few weeks back I found, that this radiostation is using Sirius satellite (feed to local transmitters)
1272943 MHz Hor 27500 3/4
But, is this even possible (that kind of frequency...)?
On the other lithuanian site i found out, that these radiostations are using PoverVu encryption. So, does it mean, that I need special card and special tuner, to encrypt these stations (if there are any stations at all, because this information is very old)...
Maybe someone (from Lithuania maybe?) knows something more about this? Thanks.
Power Vu - forget it - its the most secure encryption out, and only available to authorised broadcastwer
You can listen the M1 radio through internet at _http://www.m-1.lt/
With M-1 there aren't any problems, thats the M-1 Plius, which I'm interested in. Only 96kbps stream is available, which isn't the best quality... :( Very sad, that these radiostations aren't available FTA on Sirius... Very good (compared to that crap, that is available here on Latvia)...
you can also listen at _http://pliusas.fm/ but I don't know if the stream is ok
I know that. Stream is only 96kbit/s and buffering on the day. On evening it's working quite okay. :(
