Looking polarized for dish 3.7m
solly
Specialist Contributor
Tel Aviv, Israel
I try to check polarized mahanical ku band to use verical and horizontal
any info
I got low signal of astra 1kr and 1l
das erste near 5.8 sd chaneel
F/D ratio ?
Why are you trying to polarise signals on Ku band ?
Your best bet is to use a narrow band LNB with external reference (SMW or similar)
channel hopper my f/d 148cm
i have poor signal of mdr hd 10891h at morning 9.9db at evenig down 7.4 db
after 6.8 db start frezing
no lock signal
what type model smw need to use to get best result
That is - probably the 'f'. If the true diameter is 3.8 then the f/ d of your the Patriot works out at about 0.39.
about lnb i serch 4 port i not found primefocus any advance to buy lnb ?
They are available, but I'm not sure why you require a four port unit
The type of dish does not determine the porting, but the feedhorn assembly flange, though some designs use the collar for clamping.
