Music festivals feeds
The day has arrived. I am not wrong today!!!
Can anyone look for feeds? Just to be sure and prepare for next year...
Finaly whatching via streaming. But would be apreciated if someone could confirm the feed
I checked around and couldn't find anything. It is very likely that they are feeding this through IP and not DVB.
Isn't it time you set up your own system to check them out or do you have a problem with that? Why the interest if no intention of getting one?
I take your point but firstly I want to know if there are feeds available in order next year to prepare the set up with time. I was not possible for me this year. And apart from that I have always wondered if this kind of festivals were transmited live or not in order to prepare news headlines
Isle of Wight Festival | UltraHD RExt 4:2:2 | 16APSK
Astra 3A-3B (23.5°E)
Frequency: 11675 - Pol: H - SR: 33333 - FEC: 3/4 MPEG-4 4:2:2
Scrambled?
Has anyone had any luck watching this feed? My 32 core system is struggling with it. I'm wondering if a new graphics card would be able to play it.
23.5°E 11674, H, 33333 16APSK FEC 3/4 IOW ENC3 (SKY) 4:2:2
Isle Of White Festival in UHD !
enc in Biss
Nothing in 4:2:0 found so far :(
You may be able to play this feed on a tbs satellite card via a computer.
That is what I’m doing at the moment but it seems my PC is not powerful enough to decode the feed
You probably need a professional receiver for this feed then as they obviously do not want anyone except the broadcaster to receive this transmission.
Same problem here. Using DVB Dream. HEVC codec needs powerful hardware support, only CPU can not handle this. What H.265 codec You are using? I have LAV Video Decoder 25.10.2013
Looks like it could be a Codec issue, as my Ryzen 1800x is only running at 50% on this feed, but still not stable. I think the fact they are using 10 bit colour may be a factor too, as I saw a Portuguese league game in HEVC 4:2:2 once and that was more stable with only a minor stutter...... was lesser bitrate though.
I'd love to find out which setup can play this with minimal stutter. However this is some seriously demanding video that probably requires professional hardware. I'll do some research!
Any upcoming festivals that will be broadcast on tv?
TRANSMT isn't being broadcast on satellite as far as I know. I think they are just recording, not broadcasting
TRANSMT Festival (pre recorded)
16E: 12688Ghz V 14399Ms ID = UKI-1921P1
