OldBen
Mad Scientist
- Triax TD110 with multi LNB 28.5E, 23.5E, 19E, 13E Inverto Black Ultra's (Black Premium on 28.5) into multiswitch.
- UK
Does anyone do or can recommend aerial services in the Reading area?
Currently have a wideband high gain pointed at the Hannington transmitter, that I want either turn around to Crystal Palace or probably replace with a high gain band A so I can get Freeview HD.
Happy to turn around the wide gain if its an easier job and try it, but I don't believe it will perform well enough to get the weaker HD MUX. I have a new Blake DMX10A high gain I have tried in the loft space but the attenuation from the roof is too much, only get 3/5 MUX's receivable (signal detected for other two but too weak). Wolfbane suggests its possible so I think externally would solve.
Aerial is on T&K on end wall as can be seen in first picture of old post on dish install:
_http://www.satellites.co.uk/forums/picture-members-setups-general-satellite-installations/63537-finally-got-around-uploading-some-pictures.html
Yes I know I can whack up a minidish and get Freesat+ HD but this is Plan B...
