- Dream7020 and AZ Elite and a few DM800
- Sweden
AZBox HD Firmware – rev. 0.9.3177
(2009.08.19)
this is only TEST version
# FIXED
- CI can not support HD channel
- CI can not send the reply of ENQ
- Subtitles are transparent when menu is set to transparent
- Unicable is not working
- If playing recorded contents on movie player, recorded contents have no sound
- Can not add new SAT/TP on SAT/TP Editor
- Can not play with After recording
- If the channel has the subtitle language, which was selected on setting, subtitle
should be showed, automatically
# ADDED
- DVB-T/C NIT Search
- DTS decoding
- The menu of “Fixe Interlace on/off” on channel manager
For supporting the encoder, which may not respect the spec on this matter.
“When progressive_frame = 1 the picture is progressive, the two fields represent the
exact same time, and you should not see any comb effect when displaying the frame.
Moreover, when progressive_frame = 0, top_field_first is used to indicate which field
has to be displayed first.”
- Satellite Nile Sat 101/102/Altantic Bird4 (7.0W) is missing in the satellite list
- Telefonica transponder on Amazonas(61.0W) is missing
- Always start in TV mode
- “Automatic Reboot Option” to Timer menu
# IMPROVED
- If you choose a movie from hard disk and in the same folder where the movie is stored
there is an .srt or something else the box loads subtile automatically ordered
by .smi/.srt/.txt.
Best Regards,
The OpenSAT/AZBox Team
The dreambox killer
(2009.08.19)
# FIXED
# ADDED
- DTS decoding
# IMPROVED
by .smi/.srt/.txt.
Best Regards,
The dreambox killer
